Brake pad replacement at 10,000 miles?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by janrn, Sep 30, 2006.
  1. janrn
    janrn New Member
    Sacramento, CA
    I took my 2006 Prius to the dealer for its 10,000 mile service last week. They recommended replacing the brake pads. Shouldn't the pads last longer than 10,000 miles?
    Thanks
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,191
    Nixa, MO
    <div class='quotetop'>QUOTE(janrn @ Sep 30 2006, 09:22 PM) [snapback]326289[/snapback]</div>
    Yes, on a Prius they should last more than 100k miles. I think you need to get a lot better answer about why they need to be replaced and suggest that it sounds like a warranty issue if there's a problem with the brakes that they're wearing that quickly.
    I've not heard of anyone needing brake pads replaced on an '04+ Prius.
    See this thread:
    http://priuschat.com/index.php?showtopic=24860&hl=
  3. Tideland Prius
    16,072
    At 10,000 miles? Yeah right. Unless the pads have been rubbing all along but in that case, they should've overheated long ago. Even regular cars don't change that early IIRC.
  4. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    <div class='quotetop'>QUOTE(janrn @ Sep 30 2006, 07:22 PM) [snapback]326289[/snapback]</div>
    Unless you are harder on brakes than anyone I have heard of something is very wrong with that recommendation. Either your car has a serious problem or you drive with your foot on the brake pedal. Take your car to a different dealer or maybe to a Les Schwab tire store they will look at them free and give you an honest opinion. Then, as efusco said, if they really need replacement it should be done under warranty.
  5. efusco
    19,891
    1,191
    Nixa, MO
    Only thought, could your parking brake be rubbing? Have you fully depressed it and then let it pop up just to be sure it's free?
    And what kind of gas mileage have you been getting for the past 10k miles?
  6. janrn
    janrn New Member
    Sacramento, CA
    <div class='quotetop'>QUOTE(efusco @ Sep 30 2006, 08:21 PM) [snapback]326326[/snapback]</div>
    I will check the parking brake. We don't use it often, and I know the light isn't on. Mileage has been generaly in the high 40's. I definitely will have someone else check the brakes, and talk with the service manager where I took the car too.
    Thanks
  7. Frank Hudon
    Frank Hudon Senior Member
    4,147
    10,000 miles??? can you say "Scam"
  8. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    No Way!! I just had my 35 K check up and had >95% left on the pads. I suppose you could figure a way to chew them up in 10K but you would have to work on it real hard.
  9. Charles Suitt
    Charles Suitt Senior Member
    1,637
    16
    Dallas TX
    :unsure: Doesn't sound like the "parking brake" could be an issue. The parking brake engages the rear brake SHOES through a cable. Your comment mentioned replacing the brake PADS indicating that it would be the front disc brakes.
    Maybe you need to find another Service Department.
  10. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(Charles Suitt @ Oct 3 2006, 08:19 AM) [snapback]327301[/snapback]</div>
    I'd agree with that. If the brake pads need replacing, then there's something else seriously wrong that simply replacing the pads wouldn't fix. Brake pads aren't under warranty, but anything that makes them wear out that quickly should be. And if there's a fault in something else, the pads "should" be replaced free as well. If the dealer told you the pads needed replacing, but didn't tell you why, then he doesn't know what he's talking about (a reason to drop him), scamming you (another reason), or just pulling your leg.
    I definitely expect to get at least 100k out of my brakes, and maybe 200k.
    I could get 40k out of a normal car's brakes, but I doubt that the brake pads are even being touched, unless I make a panic stop.
    Dave M.
  11. ditto231
    ditto231 New Member
    65
    Yes, tell them go ahead and replace them. They should be covered under warranty anyway.
  12. Tom_06
    Tom_06 Active Member
    609
    141
    Newark, Delaware, USA
    <div class='quotetop'>QUOTE(ditto @ Oct 3 2006, 02:11 PM) [snapback]327399[/snapback]</div>
    Wear items like brake pads are generally not covered under warranty. These might be if another warranty fault caused the early wear.
    - Tom
  13. grizzly1
    grizzly1 New Member
    38
    <div class='quotetop'>QUOTE(Tom_06 @ Oct 3 2006, 01:45 PM) [snapback]327420[/snapback]</div>
    There is no way in H*** that I would let my dealer replace my brake pads in 10,000 miles, to wear out that quickly the car would be pulling you off the road all the time,they should last you a minimun of 75 to 100 thousand miles,make them show you why??
    I have 2 04s with #9 packs with 50,000 plus miles no problems whatever
  14. galaxee
    galaxee mostly benevolent
    9,810
    464
    MD
    hi jan-
    we're a couple miles shy of 20k, at the last oil change DH still was able to see the original rotor machining marks.
    for reference, if you take a new non-prius car a mile down the road and back, those will be gone.
    get a second opinion if you're concerned, but you likely have nothing to worry about.
    -g ;)
  15. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(galaxee @ Oct 3 2006, 02:53 PM) [snapback]327424[/snapback]</div>
    That's more like what I would hope, i.e., 20K with minimal friction brake wear. Jan's dealer is recommending new pads at 10,000 miles, which seems impossible on a regular car, much less a Prius. Or am I missing something?
  16. Ari
    Ari New Member
    165
    I think dealers like to scare customers into getting new brakes:
    1) Customer comes in for an oil change
    2) Dealer says "While we were down there, we looked at your brakes - only 2mm left! We recommend new pads and turning the rotors."
    3) Customer freaks out and says "sure, I'll pay you $200 now to avoid $500 in the future."
    This happened to me recently with my 03 Odyssey. It turned out that there was still plenty left of the pads when I measured them and I later swapped out the pads myself.
    Same thing with all the "Free 50-point inspection" coupons auto dealers like to send - it's just an invitation to find problems that aren't there.
  17. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    Best advice ever: Never trust a dealer. Instead, they say it needs to be replaced, ask them to show you the part they're trying to replace and what they want to replace it with. If it's legit, you should be able to see a problem with your part. if not, then you won't see that problem. when in doubt, get a second opinion. I've got some guys up here that would be happy to put the car up, pull a wheel, and look at the pads (in fact, we just replaced some calipers a few weeks ago in a guys camry).
  18. naterprius
    naterprius Senior Member
    1,843
    Brake pads should be covered under the 12/12000 warranty.
    Nate
  19. galaxee
    9,810
    464
    MD
    <div class='quotetop'>QUOTE(Ari @ Oct 3 2006, 03:58 PM) [snapback]327483[/snapback]</div>
    well... let's look at this from the side of a legit tech shall we?
    DH will take a quick glance over any car that makes its way into his bay for two reasons. first and foremost, because he would feel awful if he missed something that put a family in an unsafe car and someone got hurt; second, because if he just did the jobs people went in and asked him to, we'd be more broke than we are now. (honest techs don't make a lot, at least at dealerships around here)
    so if there is work that does need to be done, he's doing the customer a service by telling them it needs to be done and fixing the problem. he's also doing himself a favor by making a living.
    sure there are people who are only in it for the money. they're all over the place and they're not just mechanics. because there are a few bad apples out there does not mean all of them are rotten. you simply ask them to show you the problem and if they're not legit they don't have a leg to stand on.
  20. naterprius
    1,843
    Right on, galaxee. As an ex-Toyota Tech, people come in two types, those that believe the service guy is there to screw them, and those that believe the service guy is there to help them.
    Guess who spends more on auto repair? The guy who refuses to buy new brake pads and instead buys pads AND rotors. The guy who refuses to buy new antifreeze and instead buys antifreeze AND a water pump. The guy who refuses to buy transmission fluid and instead buys transmission fluid AND a transmission.
    I had a guy who once brought his car in for an alternator and a battery because the battery wouldn't charge. He demanded that they be replaced. I insisted that I inspect the car's electrical system, he demanded that he be allowed to oversee me so that I wouldn't try to screw him. My boss agreed to let him, and as I attached the VAT-40 and started checking things out, I discovered the positive battery terminal was corroded to hell. As I removed the terminal and cleaned the connector, the guy asked me if I had a clue. I smiled, and calmly answered, yes. I replaced the terminal, and lo and behold, the alternator and battery all worked perfectly.
    My point? The total bill was $19 for labor, $4 for parts, and $50 for diagnosis (we threw in a free inspection as well). The guy had been facing over $400 for a new alternator (Toyota's aren't cheap).
    So, this guy who knew how cars worked, couldn't see what was wrong with the old terminal, and was prepared to take it on the chin for the alternator.
    Needless to say, we had made a customer for life. That day he bought some other maintenance items and still went home with $200 in his pocket.
    Your local Toyota dealership is not in the business of "finding work you don't need". Nor are you the owner capable of determining everything that is wrong with your car the same way the technician can. (I myself might be the exception, considering I hold Toyota Certification, but that's beside the point).
    The best thing you can do is trust your instincts, and when in doubt, come over here to PriusChat.
    If you had a conventional Toyota, I'd say the brake booster is out of adjustment. Ask the technician if that can be a factor in premature pad wear.
    Nate
