Brake Pads wearing crooked???
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gertsprius, Jul 26, 2018.
  1. gertsprius
    gertsprius Member
    61
    36
    Dubois PA
    2024 Prius
    LE AWD-e
    I heard this awful scraping noise coming from the rear, it sounded like metal on metal. I peeked at the brakes and from what i could see they weren't worn at all. I troubleshooted some other ideas of what could be causing it but to no avail.. I decided to take the wheels off and take a look at the brakes closer, it turns out that the pads were worn crooked and they were the whole way to the metal on one side and perfectly fine on the other.. Any ideas of what causes this??
    51,141
    welcome!
    there is a special orientation of the rear caliper piston to the pads. how many miles on her? have you had any brake work done? have you owned her since new?
  3. JC91006
    16,672
    8,518
    If your calipers are not releasing, it could be your glide pins not lubed properly
    Grit, scona and Raytheeagle like this.
  4. Leadfoot J. McCoalroller
    7,856
    7,324
    Pennsylvania
    2018 Prius c
    ^ agreed, that wear pattern usually implicates the slider pins. The caliper should float within the range of motion on those pins. If one binds you get a weird / / trapezoidal wear pattern. If they both stick you can get all the wear on one pad and none on the other.
    Often you can free them up with some penetrating oil and exercise. Worst case, replace the caliper- though even used ones from the junkyard are usually fine. Once you get them moving properly hit them with a good thick lube meant for that job. Sil-glyde is a good example.
    Grit and scona like this.
  5. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,601
    1,690
    Bay Area
    I assume it’s your inner brake pads that is wearing uneven? There’s a nipple that you need to have it seated on the caliper piston or else it’ll cause uneven wear on the brake pad. @Mendel Leisk has a good break down with image of how it should be installed. Take it away @Mendel Leisk lol
  6. gertsprius
    gertsprius Member
    61
    36
    Dubois PA
    2024 Prius
    LE AWD-e
    I just got her in January of this year she has 78K miles on her. they were the brake pads that were on her from the previous owner. So maybe he put them on wrong. I replaced the back pads that were wearing crooked (the outer pad) myself and made sure everything was placed correctly. I will check them in a couple hundred miles to see if the problem is still there.
    Mendel Leisk and bisco like this.
  7. Mendel Leisk
    40,575
    I wouldn't leave it too long. Especially if you're unaware of the piston/pin allignment requirement, there's a decent chance they're still not right.
    A good quick check is to raise the rear (chock the fronts) and check how free-spinning the rear wheels are. There's a minor drag imposed by disc brakes, but with a good push they should spin a revolution or two, just with their momentum. If they're fighting, stop right away, you've likely got misalignment between the inner pad pin (stubby pin on back of pad) and the raised spoke pattern on the piston face. The pin needs to be between and firmly seated between the spokes, otherwise you get drag and uneven brake pressure, bevelled wear, rusty zone on about 50% of inner face of rotor.
    More info here:
    Rear brakes still binding after overhaul | PriusChat
    #7 Mendel Leisk, Jul 27, 2018
    scona, Grit, gertsprius and 1 other person like this.
  8. gertsprius
    gertsprius Member
    61
    36
    Dubois PA
    2024 Prius
    LE AWD-e
    Thank you! I will do that when I get home, I just don't understand how the Dealership missed them!
    Raytheeagle and Mendel Leisk like this.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    They are not known for their keen observation ;).
    Only when you bring them a problem you describe will their success rate improve:whistle:.
    Even with easy diagnosis, the prices can be steep:cool:.
    Good luck and keep us posted (y).
    gertsprius and Grit like this.
  10. Leadfoot J. McCoalroller
    7,856
    7,324
    Pennsylvania
    2018 Prius c
    Found your problem.
    gertsprius, Grit and Raytheeagle like this.
  11. Grit
    Grit Senior Member
    6,450
    4,186
    Wilkes Land
    They also miss things like pulling the correct engine oil nozzle dispenser to refill, tightening oil filter and oil pan screw and etc.
    So it's easy to understand, and mind boggling how they can miss something thats much more difficult.
    gertsprius and Raytheeagle like this.
  12. Grit
    Grit Senior Member
    6,450
    4,186
    Wilkes Land
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
  13. gertsprius
    gertsprius Member
    61
    36
    Dubois PA
    2024 Prius
    LE AWD-e
    I took a look at the brakes and they were still worn crooked. I then checked the slide pins low and behold one of them was seized. I took the good ole penetrating spray and went to town and getting it loose. I was able to loosen the pin and i re greased it and the other one just for good measure. i replaced the brakes again. Here is some picture evidence of what the pins do to the pads compared to the other pad that was worn normally.
    bisco and Raytheeagle like this.
  14. bisco
    51,141
    thanks for the update, well done!(y)
    gertsprius likes this.
  15. Grit
    Grit Senior Member
    6,450
    4,186
    Wilkes Land
    Yikes. Who last touched them?
  16. gertsprius
    gertsprius Member
    61
    36
    Dubois PA
    2024 Prius
    LE AWD-e
    I assume the dealer. I believe they were the stock brakes!
  17. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Instead of starting a new thread, I will report my brake experience here. This was my first brake job. Was unplanned. I originally wanted to lube the caliber slide pins during the annual Spring tire swap. Never done this task before either. While the pins were off, I inspected the brake pads. The inner ones were worn, but not through the metal yet.
    Went out and bought new pads. The rotors were still good. Replaced the front pads and lube the pins without problems. The back ones a different story. The right rear slide pins were seized. Had to bang them out with large screwdriver and mallet. They were corroded, decided to replace them. Also had to buy the rear caliber piston screw tool. In summary, was able to get the job done. :)
    The original brake pads lasted 145K for over 6 years.
    #17 Bay Stater, Apr 14, 2019
    RMB, scona and Raytheeagle like this.
  18. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    Looks like checking further was prudent :).
    Now to perform the service more frequently ;).
    The fun of living in the salt belt(y).
    Bay Stater likes this.
  19. Mendel Leisk
    40,575
    Since you haven't mentioned this, I'm compelled to mention:
    Caliper piston spoke pattern orientation is important on the rear brakes. It should be oriented like an "X" when reassembled, so that the stubby pin on back of pad is between spokes. And you need to ensure everything's well seated thus, the piston doesn't manage to rotate, ride a spoke up on that pin.
    Long story short, to check/verify: raise the rear and spin a wheel; it should spin a revolution or two, fairly easily. If it's dragging badly it's likely that piston orientation, should be checked.
  20. Mendel Leisk
    40,575
    That's not good:
    Don't tell me this was the first time the brakes had a proper inspection. Toyota USA recommends an in-depth brake inspection, tri-yearly or 30K miles, whichever comes first. For good reason. Sadly, they don't spell it out that clearly, but have a look, it's in the Warranty and Maintenance Booklet, pretty much buried and low-key.
    #20 Mendel Leisk, Apr 14, 2019
    Rebound and Bay Stater like this.
