Brake pads
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Legogo, Apr 1, 2020.
  1. Legogo
    Legogo Junior Member
    42
    Azerbaijan
    Hi. It's time to change my front break pads on my Prius C 2014.
    What label can you suggest me? A
    re the break pads from prius C and prius 20 the same?
  2. Mendel Leisk
    38,729
    Do you have Toyota dealerships where you are? The simplest way to get the right pads (and shims) is through a dealership parts department, if possible.
    If you need to order, I believe this is the part number:
    04465-52320
    based on this (US) website (item #17):
    Front Brakes for 2012 Toyota Prius C | Toyota Parts
    I'm not seeing the shims there. And I would suspect ordering that part number, you would get sufficient pad for all front brakes. Perhaps shims are included, not sure.
    Amayama might work for you:
    Genuine Toyota 04465-52320 (0446552320) PAD KIT, DISC BRAKE, FRONT - Amayama
    I've used them several times, very reliable and good prices. Besides shipping charge, no extras like taxes or import duties.
    #2 Mendel Leisk, Apr 1, 2020
