Brake peddle travel distance when powered down and when just powered on?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by drive till it HERTZ, Aug 29, 2013.
  1. drive till it HERTZ
    drive till it HERTZ New Member
    What is the brake pedal travel distance to the floor before starting the car?
    Had the Brake Accumlator Recall done and the brake software update. Now the peddle goes to the floor before starting the car. Always had only about and inch of total travel. Is this normal? I do not feel safe. Car brakes good after shifting into drive and starting to move.
  2. gliderman
    gliderman Active Member
    751
    223
    No. You need to take it to the dealer who did the recall and tell them to fix it.
  3. Former Member 68813
    3,524
    981
    US
    Say, are you the same person as the member abra ?
    You have a lot if things in common, including "peddles" in your cars.
