Brake problems
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Jason z, Oct 24, 2021.
  1. Jason z
    Jason z Junior Member
    Two Eco
    I have a 2016 prius eco two. I replaced the wheel bearing hub and accidently let the caliber pop out of the front left side. i put it back in bleed the brakes but since then every warning light is on. It has ABS fail and Low power to brakes. How can i reset these lights or go into a mode where i can bleed everything properly and reset the lights. The car drives fine and brakes.
  2. Mendel Leisk
    41,859
    Think you need Techstream and/or a visit to the dealership. How'd you bleed the brakes btw. See attachment:
    vvillovv likes this.
  3. Jason z
    Two Eco
    OK ty. Is Techstream something i can buy or is it a dealer only item. If so whats the best one to purchase
  4. Mendel Leisk
    41,859
    Just getting the dealership to remedy things would be a lot cheaper, than buying Techstream legally: it's in the $1000's. You can get bootleg copies and aftermarket cables, and install on an old Windows laptop, but that's out of my league.
