Brake Repair Question
Discussion in 'Gen 2 Prius Main Forum' started by Bluesman78, Mar 14, 2017.
  1. Bluesman78
    Bluesman78 Member
    162
    46
    Boston
    I just bought a used 2006 with 96,000 miles. It was always maintained at the dealer. When reviewing the records I came across this as the last service record
    BRAKE DRUMS (REAR) - MACHINE (BOTH) ~|~ ~|~,CUSTOMER DECLINED SERVICE -
    Obviously the work wasn't done, but I was wondering how I should proceed.
    From what i understand the dealer was recommending a brake job for the rear breaks and to machine the rotors?
    Questions:
    1) What work exactly needs to be done? Pads, Calipers, Drum(?), Rotors? and what is the approximate cost for this in the New England USA dealership.
    2) How necessary is the work at all? I don't hear any sounds from the brakes (i thought brake pads had a warning sound - my old Acura did)
    3) I don't want to get my car serviced at the dealer, should I go to my independent guy and ask for a brake check? The car drives fine and passed inspection in October. I was going to get my transmission fluid changed and an oil change and I didn't think anything else needed to be done at that point.
    FYI: there was no record of a rear brake job on the records from the dealer, so I don't think any brake work was done on this vehicle!
  2. djasonw
    djasonw Active Member
    950
    116
    Coconut Creek, FL
    The rear brakes in this car have a relatively easy life. First off, in most vehicles, the majority of braking comes from the front brakes. Since the Prius is a hybrid, it recaptures energy from braking which in turn means that the friction pads are used less often. At 96,000 miles it seems early for the rear brakes requiring replacement. It's possibly the car was driven more aggressively or in lots of city type driving. If I were you, I would have it checked out at a reputable brake shop to get their opinion.
  3. Bluesman78
    Bluesman78 Member
    162
    46
    Boston
    Thanks for the quick reply. What is the typical lifecycle for the front brakes?
    Also I think the rotor machining is a scam. I remember they would say to do that on my Acura by the dealer all the time.
    49,602
    agree completely^^^ maybe have them take a look at your next tire rotation. very likely the dealer just needed to make a boat payment.
    TWOPrius and Bluesman78 like this.
  5. bisco
    49,602
    front pads usually last between 100 and 150k. but they can measure pad thickness, so it's not a guessing game. toyota has specs for pad and rotor wear.
    TWOPrius likes this.
  6. Mendel Leisk
    38,794
    2nd rears are drums. Used vehicle, with that mileage, it wouldn't hurt to have a look-see. The fronts as well. Was there any other brake service notes in the service record?
    Three years or 30,000 miles is a good interval for an in-depth brake inspection, one that goes beyond the visual look-over while the tires are being rotated. That's Toyota's recommendation for 3rd gen in the US, not sure about 2nd gen, but I'd suspect it's the same. This is regardless of pad/shoe thickness. Like going to the dentist before you have a toothache.
    OTOH, I seriously think service departments are machine happy. Pad/shoe thickness check, disc/drum thickness/dia check, and disassemble/lube/reassemble of all spec'd contact points, yes. But drum and rotor machining is overdone, in my opinion.
    One thing, when the rear drums, or front calipers, are off, you need to be real careful. An independent shop might get caught off-guard: if you do something like open the driver's door (at least with 3rd gen): the system will pressurize, can pop a piston right out. And if excess brake pedal is detected post-inspection, the car may throw codes.
    Two good tacts:
    1. Disconnect 12 volt battery before any assembly.
    2. Pump brake pedal multiple times, before reconnecting 12 volt.
  7. Bluesman78
    Bluesman78 Member
    162
    46
    Boston
    1) No other brake service was done, however, all scheduled maintenance up to 96K was done at dealer, which included some brake inspections
    2) So drum brakes can be machined too? then I guess that's what they meant? If so, I'm certain the dealer needed some dough lol.
    I will have them take a look at my next tire rotation.
    Mendel Leisk and bisco like this.
  8. Mendel Leisk
    38,794
    If you don't already know: there a trick for getting stuck drums off. Use a pair of M8x1.25 (by say an inch long) bolts, screw into threaded holes on drum face, to help break it loose. Just go back and forth, screwing them in bit by bit. Eventually, and sometimes kinda dramatically, they pop free.
    #8 Mendel Leisk, Mar 14, 2017
  9. ChapmanF
    15,791
    Yeah, it's so easy to take the rear wheels and drums off and see for yourself, it's hardly worth having someone else do it and then having to wonder what they really saw.
    My Gen 3 (discs all around), I just measured the lining thicknesses on at my last tire rotation, and they are all about exactly 50% from new-spec to end-of-life spec, at about 120,000 miles.
    With a Prius, lining wear really isn't the thing that motivates brake maintenance; you still need to check somewhat regularly just to make sure the hardware isn't binding up, wear getting uneven, etc. If you just go by how slowly the linings wear, you may be letting other issues go too long.
    -Chap
  10. oil_burner
    oil_burner Active Member
    249
    126
    machining rotors is really a waste of time at the rates shops charge. Rotors and drums are dirt cheap nowadays when you can get a new rotor for $30 it makes more sense to just replace rotors and pads as a set. When my dad's civic wore down to metal on metal, I put on new rotors $60 and pads $60. The only thing I would pay the shop to do is a brake service which is cleaning the pistons and lubricating the sliding pin because its a pain in the nice person.
  11. Bluesman78
    Bluesman78 Member
    162
    46
    Boston
    Can you visually inspect the brake pad?
    I agree, never doing any machining again, always did it in the past (guilted into it by the dealer) but now never again!
  12. Mendel Leisk
    38,794
    Nine times outa ten neither machining OR replacement is needed.
  13. 05PreeUs
    05PreeUs Senior Member
    1,097
    563
    MSP
    ROFLMAO, sounds like another CarTalk listener ;)
  14. bisco
    49,602
    loved the click and clack.;)
  15. 05PreeUs
    1,097
    563
    MSP
    The actual facts are: a) it would be EXTREMELY rare to have enough wear at that mileage to warrant new shoes; b) IF new shoes were installed, they WILL have a different "arc" than the worn drums they will contact; c) unless the SHOES are arced to the new or turned drums, there is no sense in turning the drums at all.
    There is enough flexing in the shoe tables (the metal parts the friction material is bonded to, to allow nearly 100% contact upon brake application.
    In order to do drums brakes "by the book", you not only need to turn the drums (new or used), but to match the shoe arc to those newly turned drums - no one does this any more and I highly doubt I will ever meet another person who, as I, have this experience.
    As for rotors, first reline you leave them, second replace them with new.
    PS: DO NOT think that cheaping out is a good idea with brakes, they are one of only two safety systems on a car, the other is steering.
    valde3 likes this.
