Brake reservoir strainer/filter
Discussion in 'Gen 3 Prius Main Forum' started by tacopyro, Jan 20, 2021.
  1. tacopyro
    tacopyro Member
    86
    42
    Los Angeles
    Hello, just wondering,
    in the last year or so we've acquired 2 gen3 priuses and i just noticed that both did not have a strainer in either brake reservoirs. is this normal ? or everyone else has a strainer ?
    even some online videos i've seen didnt seem to have one...
    if there is a strainer? where can i get one without buying a reservoir? so far i dont see it in the parts diagram either.
    Thanks.
  2. StarCaller
    StarCaller Senior Member
    1,271
    723
    Cedar Crest, NM, USA
    no strainer for the prius /
    tacopyro likes this.
  3. tacopyro
    tacopyro Member
    86
    42
    Los Angeles
    Thank You StarCaller.
    i find that ... interesting. i do see the plastic has the support for a filter. just no filter.
  4. Mendel Leisk
    40,582
    Ours has some sort of strainer basket. It has a slit running down the sidewall that you can slip a very skinny spigot or tube through, say when basting in prep for fluid change.
  5. tacopyro
    tacopyro Member
    86
    42
    Los Angeles
    Thanks Mendel,
    do you have a pic ? also what model Prius do you have? by model i mean like ZVW30-AXXEB or such?
  6. Mendel Leisk
    40,582
    I have a 2010 Canadian Touring. I think it’s roughly comparable to US 2010 level “V” (aka 5, from 2012 onward?)?
  7. tacopyro
    tacopyro Member
    86
    42
    Los Angeles
    I've looked at jp-carparts, megazip, toyodiy and all of them do not show a strainer. Thats of the different variations out there.
    Other cars do show a strainer part, but the gen3 Prius definitely does not show any. The NHW20 gen2 does show it has one.
    I've asked ebay sellers and none seems to have a strainer so i'll stop looking from a OEM pt of view. Thank You for the confirmation.
  8. ColoradoBoo
    ColoradoBoo Senior Member
    1,140
    748
    Monument, Colorado USA
    In our 2017 Prius 2, there isn't a filter but it does have a plastic divider in there that prevents you from sucking out the old fluid when doing a change. So I just bled more out of each wheel to get it all changed out....stupid design!!
