"Brake Service" every 2 years/32,000km.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tideland Prius, Aug 3, 2011.
  1. Tideland Prius
    16,158
    So I just had my 24 month/32,000km service today and was a little taken aback at the cost of the brake service. It's a new menu item on the 2010 Prius (It wasn't on the Gen 2's maintenance schedule in Canada. Maybe they've had some issues with rusty rotors/drums?) and it's required every 2 years or 32,000.
    It cost me $118 to inspect the brakes at each corner. Does this kinda defeat the purpose of the brake pads lasting (essentially) the life of the car and the associated cost reduction? A set of pads cost, what, $150++? Our 2005 Prius with nearly 170,000km still has 75% brake pad life left and it's done mostly city driving (no highways on the commute).
    In other news, I have 85% brake pad life left which is ok.
    How does the US maintenance menu compare? other provinces?
  2. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    We don't have that requirement for the U.S. Gen III at 24 month/20,000 miles. Is that actually listed in the Canadian 2010 Prius Warranty & Maintenance Guide? What does it say exactly? All we have is "Visually inspect brake linings/drums and brake pads/discs" every 5,000 miles or 6 months.
  3. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    In the US, every 5K miles / 6 months calls for:
    And at 30K miles / 36 months:
    Inspect the following:
    --Brake linings/drums and brake pads/discs 3
    3 Inspect thickness measurement and disc runout.
    So the 30K mile / 36 month service appears to be more detailed.
  4. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    Well, good thing I do my own maintenance every other 5K miles and take it in only at 5K, 15K, 25K, 35K, etc. and avoid the pricey 30K "special." Oil change is needed only every 10K and I have the dealers rotate tires every 10K miles (as the OEMs have no warranty anyway).
    I just changed my own engine and cabin air filters when it hit 30K this past weekend.
  5. Mendel Leisk
    38,733
    Tideland,
    What you had done seems to agree with US Schedule. Take a look at my posting for US maintenance schedule. Also, it does not seem out of line: a cursory check of brakes yearly, and a more thorough "service" bi-yearly, is not excessive.
    The service typically entails physical removal of the pads, for a better check of thickness, and to relube the faying surfaces, between shims and pads and calipers/pistons. It's also worthwile checking disc runout, thickness, parellism, especially if there's any reports of brake pulsing. Also, all brake lines are checked for integrity and leaking.
  6. bisco
    49,504
    $118.? scam/ripoff.
  7. Mendel Leisk
    38,733
    Maybe in the States. In Canada that's about the going rate for a 4 wheel brake service.
  8. stream
    2,977
    452
    Long Island, NY
    I don't think so--see my post above.
  9. Mendel Leisk
    38,733
  10. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    So Canadian 32,000km / 24 months is similar to U.S. 30,000 miles / 36 months.
    It's easy to avoid those pricey 30K and 60K "specials" if you're allowed every 10K miles oil change. Just replace your own engine and cabin air filters.
  11. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    82
    Camas, WA
    Does the owners manual for the car state that brakes should be inspected evey 2 years, or did the dealer just print up a generic service schedule for all cars they service, and since non-Prius needs to have the brakes inspected evey 2 years, they just wait so see how many Prius owners will just assume it is needed and do it.
    I am not saying for sure that is what is going on here, but here in Washington, I have seen for example, the Honda dealer has printed their own official looking maintenance schedule they apply to all customers, no matter which model Honda they drive.
    It reminds me of a story my father used to tell about a shady food store in our small town. They kept a new broom leaned up against the checkout stand. Then whenever anyone checked out with enough groceries that the clerk thought they would not notice, the clerk would ring up the broom with their order. If the customer noticed, they would appologize and take the broom off the bill, but if the customer didn't notice, they would walk away having paid for the broom, yet leaving it there to be sold again and again. Could the brake inspections on a Prius be like this broom?
  12. Tideland Prius
    16,158
    Ok. But note that it's not part of the Maintenance Service. It's an extra cost "mandatory" service according to the Supplementary Owner's Manual and the Maintenance Menu online. Note that this isn't present in our 2005's maintenance menu. There is no such item.
    No. The visual check is part of the Maintenance service (~$120). This brake service was in addition to the maintenance service so my total was close to $300 after taxes.
    C&P from the maintenance menu...
    Current Service
    32,000 km
    Maintenance Service
    + Replace engine oil & filter
    Remove & inspect engine air filter element (replace if required,
    additional charge)
    + Lubricate locks, latches & hinges
    + Confirm lights, horn & wipers function properly
    + Check coolant, brake, transmission & washer fluid levels
    Perform battery service and comprehensive electrical charging system
    evaluation
    + Inspect valve clearance (audibly)
    + Inspect drive belts for damage, adjust tension if required
    Check steering gear box, linkage and shock absorbers for looseness,
    damage or leakage
    Inspect ball joints and dust covers, driveshaft and steering rack boots,
    chassis nuts & bolts for looseness or damage
    Remove wheel and brake drum, check pad/shoe thickness. Examine
    brake calipers, wheel cylinders and brake lines.
    + Inspect fuel and exhaust systems for leaks or damage
    Examine tires for damage and wear, check & adjust pressure (rotate if
    required, additional charge).
    + Perform road test.
    Brake Service
    Replace Cabin Air Filter
    So 3 items to do at 32,000. Maintenance at ~$120, Brake Service at $118 and Cabin Air Filter at $51 (Which I decline since I replaced it myself in June with a better filter)
    It's listed in the manual. It's a new item for 2010 because it's not on the maintenance menu for our 2005 Prius.
    I looked at the Supplementary Owner's Manual and it appears that this "Brake Service" applies to Corolla, Matrix, RAV4, Venza and Prius.
  13. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    So you don't have the equivalent of the Magnuson-Moss Warranty Act, which allows you to take it to a cheaper independent shop or even perform your own brake service in order to keep the warranty intact?
    Seems like an unnecessary expense but I guess you're stuck with it.
  14. bisco
    49,504
    i suppose if you intend to keep the car for 100,000 miles+ it's worth it?
  15. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    I would not want anyone taking my brakes apart to inspect them, I think it will cause more problems than it will find. We have already had one topic on here about caliper bolts that were left out after brake inspection: http://priuschat.com/forums/gen-iii...leshooting/96300-thoughts-loose-calipers.html A good visual inspection when rotating tires should suffice. If it isn't broken don't fix it!
    Pad thickness can be measured without taking them apart. If there are fluid leaks chances are you will not have them coincident to the two year inspection schedule anyway. However you may notice the fluid level getting low or see the fluid on the calipers or rotors when you rotate tires. When the pads wear down you will hear the wear sensors then take the brakes apart and check everything when the pads are replaced.
  16. Tideland Prius
    16,158
    Not that I know of. I have no problems taking my Prius to a Toyota dealer because typically maintenance costs are quite low (and I've seen others who decided to take it an indepedent shop and I've seen how their cars look like after 10 years...).
    It is, especially since it's only on a handful of Toyotas (As listed above) so I'm not sure why some are necessary and others now. More importantly, how does it differ from the normal visual inspection that's included in the maintenance service as listed above.
    Perhaps but I'd like to know what they're checking up and beyond what's listed in the maintenance schedule.
    Maybe I'll ask Toyota and see what's done up and above the normal brake stuff found on the Maintenance Service portion.
  17. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I believe due to the Prius regenerative brakeing the brake pads
    should last a long time. I know on our Prius with over 50,000 miles the brake pads still looked great with no noticeable wear.
    alfon
  18. oldasdust
    oldasdust Member
    356
    47
    illinois
    The more things are taken apart then put back together can lead to problems with all fasteners not put back or correctly tightened. Years ago a friend who was a design engineer at Gm told me the cars today are built with no error allowed. If one bolt, nut or screw are missing, torqued incorrectly problems down the road after many miles can occur. They pulled vehicles out of line after assembly and took completly apart and documented errors and were averaging almost 100 bolts, nuts,screws missing or incorrect torque per vehicle. Robotics changed most of this not programed to be lazy, just inferrior parts made cheap by unskilled labor still sometimes an issue.
  19. Carzone
    Carzone New Member
    50
    33
    Toronto
    Another typical rip-off for Canadian only in North America.
    First is the 8000km/6 months oil change interval, and now this.
    Here is the logic: less people, smaller market, weak government, more rip-off
    This can be applied to any company. You have to pay more and get less, just because you are in Canada. By the way, I think Australia has the same story.
  20. Carzone
    Carzone New Member
    50
    33
    Toronto
    Tideland Prius
    Do you know what did they do for this $118 Brake Service?
    Did they replace anything, such as the fluild or pad? Or they just opened it and had a look.
    My prius still has half year to reach this 2 year service. If they just look at the brakes and charge me $118, I will not allow them to do so.
