Brake Sound when Stationary
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by BlakeFL, Oct 18, 2018.
  1. BlakeFL
    BlakeFL Junior Member
    Orlando, FL
    When stationary and lightly pressing on the brakes there is an air sound that doesn't seem to be going away. Anyone experience something like this? Brakes work fine but it's pretty annoying.
    49,504
    what are you driving? it sounds like a prius brake accumulator. pretty normal, did you just get it, or is it a different car?
    Pluggo likes this.
  3. Pluggo
    Pluggo Senior Member
    608
    532
    Folsom, Pennsylvania
    Very glad for the video because that was an electric motor whir, not a hiss.
    49,504
    yes, to me, it is a buzzing sound
  5. BlakeFL
    Orlando, FL
    This is in a 2013 Prius that I have had for a few years. The sound at 4 and 19 seconds is normal and I believe is what builds pressure in the brake system. The other sound that is present throughout the whole video is the annoying one I'm talking about. To me it is more of an air hiss sound than buzzing.
  6. bisco
    49,504
    i'll listen again. fyi, you can add your model info under your avatar where it says 'other non hybrid'.
  7. bisco
    49,504
    is it the cricket like sound?
  8. BlakeFL
    Orlando, FL
    If that is the sound you hear throughout the whole video, then yes. To me it sounds more like small burst of air being released.
  9. bisco
    49,504
    definitely not normal, but i don't recall ever hearing it before
    if the actuator is leaking, you usually hear the buzzing of the pump more often and for longer periods of time
