Brake Switch Replacement...DIY?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Oceansurfer, Jan 11, 2017.
Tags:
  1. Oceansurfer
    Oceansurfer Junior Member
    Dealer informed me today that my brake switch needs replacement. $350 with parts, labor and diag. Is this an easy DIY? Anyone have a manual/diagram etc?
  2. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Not if they have to bleed the brakes need a computer to do that
  3. Oceansurfer
    thanks for your reply jmack. hmm...I was under the impression that it was just an electronic switch somewhere behind the pedal. Have you done it before?
  4. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    There is on there mostly you could do it I seen a video have to mark something and don't break the mount find the video
    I was thinking about something else on bleeding
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    I remember looking for the brake switch on my wife's '05 before a texter totaled it. I wanted to adjust it because it was taking more pressure than I think it should to disengage the cruise control. I could not find a switch behind the brake pedal. Maybe it's actually there and I couldn't find it?
  6. valde3
    valde3 Senior Member
    2,002
    746
    Finland
  7. Oceansurfer
    Thank you valde3, that is exactly what I was looking for! After looking at this, I think I'm going to have Toyota handle it. I took the car in to troubleshoot the Brake Actuator Assembly under T-SB-0032-16 (my Brake/ABS lights have been illuminated on the dashboard). I was hoping to have it replaced under warranty but they identified the Brake Switch as being faulty and need to start troubleshooting there first.
