Brake symbols
Discussion in 'Prius c Main Forum' started by eliam, Apr 8, 2019.
  1. eliam
    eliam Junior Member
    new york
    Help needed Im getting the brake ,abs
    Damper and stability control symbol all at tge same time on my car it drives ok mileage is fine and I just replaced the 12v battery which I did afterwards. Any ideas
  2. joelg1988
    joelg1988 Junior Member
    34
    32
    Las Vegas, NV
    2018 Prius c
    It's hard to diagnose without pulling ABS codes from the OBDII port, however maybe you hit a pothole and damaged the ABS sensor? Did you change wheel diameters? Check Brake Master cylinder for fluid level/leaks. I don't know for the C, but for my Camaro, both the Stabilitrak and ABS lights turn on when the brake fluid is low.
    49,500
    how many miles on her?
