Brake Warning Light
Discussion in 'Generation 1 Prius Discussion' started by kenopa, Jan 5, 2010.
  1. kenopa
    kenopa Junior Member
    57
    Indiana
    Looking for some advice. Currently in Little Rock making my way to Houston. Temp here in morning is 16. Prius started OK. Pulled out of parking spot. After first stop, brake warning light comes on and car feels like something restricting motion (like holding car back a little). Brakes felt OK in all other respects (as in they stopped vehicle and then appeared to release). After couple minutes of warm up (slow driving), light out and restriction feeling gone (Tests in hospital today so had to proceed). Light out all day with temps in 30's (drove about 60 miles). Brake fluid OK. Pads/shoes OK. Emer brake was not used. Something is related to extreme cold but cannot id. Car not pulling to one side. Can be trouble in master cyl? Water freezing in system? No other lights/codes. Maybe should take to dealer here but have nothing to show him. Ideas?
  2. bwilson4web
    15,528
    How many miles on the transaxle oil?
    Tire air pressure?
    Alignment?
    Has a brake shop tested the fluid for water? (thx Doug)
    How old is the 12 V battery? Has it been tested? (thx Patrick)
  3. kenopa
    57
    Indiana
    Updated info. Wife now informs me that several weeks ago (following another cold night), emer brake would not release. Pedal worked but light stayed on and vehicle did not want to move. After warmup, she heard clunk from under vehicle and light extinguishes. Vehicle then fine in all respects. With that, I now believe that problem may be with rear shoes freezing to backing plate overnight. As I understand the manual, if brake system failing, brake light is accompanied by buzzer, which I do not experience (by the by, temps today in 30's, so no brake issues at all). I intend to remove, inspect and clean rear brakes when I return from trip. For Bob: transaxle fluid has 62,000 miles, tires at 42 pounds, alignment I don't know but she drives arrow straight, water in brake fluid I don't know how possible but valid concern, 12v battery about two years old and not tested. Vehicle liberally covered with road salt from 600 mile drive in crappy weather so that could be factor.
  4. bwilson4web
    15,528
    Good call on frozen brake shoes and/or the parking brake cable and linkage. I live too far south to get much cold weather experience.
    OWCH! We have history of the hydrocarbon capture device linkages getting corroded and leading to it being blocked and an expensive repair. The HC routes the exhaust gas through something that captures the initial, hydrocarbon rich gas flow. Once the car is warmed, the valve opens and there is a straight flow to the catalytic converter.
    When the 'salt season' is over, you might lift the car and check the linkage, clean off any corrosion, and apply a high temperature lubricant to the moving parts. There are no guarantees in life but others have done this.
