brake warrantee enhanced ?
Discussion in 'Gen 3 Prius Main Forum' started by privilege, Aug 23, 2021.
  1. privilege
    privilege Active Member
    659
    169
    Birmingham
    help ! I had a bookmark for the "enhanced" brake accumulator/booster warrantee, but can't find it.
    would one of you fine folks that are familiar with the "enhanced" part the expires THIS MONTH please link me to it ?
    i need to make an appointment and have mine replaced, hopefully under this warrantee ;-)
    THANKS !
  2. jburg
    jburg Member
    93
    RTP, NC
    I will look back at the TSBs, but I believe they won't replace it unless it throws a code or exhibits the issue.
    Customer Support Program ZJB
    "Secondary Coverage is applicable for 10 years from the date of first use or 150,000 miles, whichever occurs first."
    "Which brake system warning indicator may be related to these conditions? A1a: If the following warning lamps are illuminated, the vehicle may be experiencing a concern with the brake booster and brake booster pump assemblies which are covered by this Customer Support Program."
    I don't think they will just replace it in the warranty period if you aren't experiencing an issue, but you can call up Toyota USA and ask.
  3. jburg
    jburg Member
    93
    RTP, NC
