Brakes already!?!?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Prigirl, Jul 8, 2019.
  1. Prigirl
    Prigirl Junior Member
    Ohio
    Hi everyone. I have a 2016 Toyota Prius with just around 33,000 miles on it. On my last trip to the dealership, they told me I need the front and rear brakes replaced to the tune of $1300. I declined the service and took it to a local mechanic and he said the same, although at a much lower price at least ($630). I know this is odd and I literally do maybe 10 minutes of 'city driving a day and from what I hear the brakes should last far longer. Now, I just want to know what I did wrong or what I can do prevent this in the future on this or another Prius down the road. I am the only owner of the car so it must be something I did. I've tired to look around and not bother anyone but it seems me and my problem child Prius are kind of an anomaly. Any thoughts or advice would be much appreciated.
    ETP and bisco like this.
    49,493
    welcome!
    yes, it is very unusual. i think someone else just reported same on a 16 w/ 38k or something.
    do you think you could have the mechanic show you what he is seeing, grab some pictures and record your conversation to post here?
    Aaron Vitolins and Prigirl like this.
  3. Prigirl
    Ohio
    I will certainly try. I am interested that someone else had the same issue so soon. I also don't know if I should take it to a local mechanic or to a dealership. I will not go back to the one I originally went to as they had a laundry list of unnecessary upsells they tried to get me to do in addition to the breaks. It was also very high pressure and an unenjoyable experience to say the least as this was my first appointment without Toyota Care it seemed like they just wanted to rake me across the coals. Really appreciate the input and the warm welcome. :)
    chinarut and bisco like this.
    49,493
    are you having any problem with the brakes? perhaps they're all just trying to clean out your wallet.
    William Redoubt likes this.
  5. bisco
    49,493
  6. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    Salty environment in the rust belt leading to brake components not working well:whistle:?
    At least in these 2 examples that sounds likely (y).
    Prigirl and krmcg like this.
  7. CooCooCaChoo
    CooCooCaChoo Senior Member
    901
    504
    Cow-lee-fornia
    2023 Prius
    Yeah, salted roads during the winter would be a significant factor.
  8. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    Doesn't sound right to me - mine have done almost 30,000 miles - and look barely worn at a glance. It's in for service tomorrow, so I'll ask them to have a closer assessment for me.
    I'm a fairly gentle driver though, and usually got good life out of brakes.
  9. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    There's no normal reason for the brakes to wear out that quickly. 150-200k miles is more typical. Unless you're a very aggressive driver, it seems to me like it would require all four brakes to be dragging for them to wear that quickly. And that would give you really bad gas mileage (as would the aggressive driving).
    Did they say it was pads, rotors, or both? It might help to know exactly why they want to replace them.
    #9 jerrymildred, Jul 9, 2019
  10. CooCooCaChoo
    901
    504
    Cow-lee-fornia
    2023 Prius
    Or ... the extreme here ... I know a girl who drove around with her parking brake on and burned up her brakes.
  11. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,801
    1,170
    Auburdale FL
    My dealer tried to sell me a tranny flush, brake flush, radiator flush at 24K.
    I have never flushed the bakes or radiator on a Prius.
    Tranny is drain and fill only and only if you keep it long term.
  12. ETP
    2,801
    1,170
    Auburdale FL
    If that includes 4 new rotors, 4 new calipers, and hardware then ok if you can verify it was actually done.
    Prigirl likes this.
  13. Prigirl
    Ohio
    Yep I am a girl, what an astute observation. No, I have not been driving with my parking break on, nor have I done what I would call aggressive driving with the car. If I did, I think I would know what the answer as to why they need replacing already and wouldn't have bothered to ask for advice.
    ice9, mikey_t, kithmo and 6 others like this.
  14. Prigirl
    Ohio
    I wasn't having any problems with them but two different places have told me they need replaced so I am pretty sure they need replaced at this point. I was going to take it to one other place to a price from them as well.
    ETP likes this.
  15. Prigirl
    Ohio
    The garage did not tell me why or what needed replaced. The local mechanic said it was the pads. He thinks it is the salt and the fact that I don't use the actual brakes very much. Most days I drive about 30 miles round trip on a very open road at 45 miles an hour with little traffic. The last five minutes of my commute end in what I would call city driving where I actually use the breaks and there is traffic. I get around 56 miles to the gallon when it isn't winter. The local mechanic seems like an honest person, and I went there on advice from a friend who has gone for years to him. That being said, I am also worried about not having this done at a Toyota shop, but the price difference is pretty extreme. Is that just for Toyota parts?
    mikey_t, jerrymildred and ETP like this.
  16. bisco
    49,493
    i wouldn't take anyones word for it, no matter how many places tell you. to need brake work without any symptoms is very unusual.
    don't waste your money until you're convinced
    Montgomery, krmcg and Prigirl like this.
  17. ChapmanF
    15,622
    Brakes are funny. They can last for years and years and 200,000 miles or more before wearing out, if everything goes right. They can also develop a small problem, pick up a piece of road debris, etc., that can do them in quickly, in between the last time you inspected and found no problem, and the next time when you find a situation requiring parts replacement. That can certainly happen if you're following Toyota's only-every-3-years-or-36,000-miles inspection recommendation.
    Often little problems like that can be nipped in the bud if caught early, just by looking at the brakes more often. They are super easy to look at whenever the tires are off, say for tire rotation, which would have given about five chances to peek at the brakes already on a 33,000 mile Prius.
    Also, I very much recommend boldly jumping in and inspecting the brakes yourself. It isn't hard to give them a quick look, and it's the ultimate protection against mechanics using vague brake "problems" as sources of boat payments, which, regrettably, does seem to happen.
  18. alanclarkeau
    7,044
    7,584
    I've just come back from my car service - I asked them to check how much the brakes were worn.
    They said there's over 10mm left - and considering that there was only 12-13mm originally, at this rate they said I should be right for 200,000+ km. It's driven 45,342 kms - which GOOGLE tells me is 28,174 miles.
    Did you buy the car new?
    Prigirl, ETP and Raytheeagle like this.
  19. ETP
    2,801
    1,170
    Auburdale FL
    All good info and my daughter is better mechanic than my son in law.
    Stuff happens for sure. Someone was sloppy with an air wrench etc, you hit an object, salty roads, part failure. We taught at the votec that you: start the the lug nuts with your fingers, then use an air wrench at a very low setting, then hand tighten and torque with a crisscross pattern just like a head job.
    Some dealers do it correctly (one dealer actually had a safety checker) and they should brakes at every oil change. A good look at the rotors will tell the story.
    Anyone try those Chinese rotors from Autozone for a Toyota? I have had OK luck with other vehicles.
  20. jerrymildred
    11,511
    14,113
    Tampa, FL
    Well, salt is brutal. I lived in Ohio and Iowa for a large part of my life, so I know what you mean. And it can ruin brakes.
    As to the price difference, it's probably a combination of Toyota parts vs generic and a difference in labor rates. Any brake shop should be able to work on your brakes as long as they know to disconnect the 12V battery so the Prius' brake actuator can't come on while the brakes are apart.
