Brakes Chirping At Around 10K
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by warcat507, Sep 4, 2007.
  1. warcat507
    warcat507 Junior Member
    17
    I only have about 10,500 miles on my '06 Prius, and this morning the brakes started chirping. Sounds like it's coming from the rear brakes. Sometimes it even continues for a while after I let off the brake. Doesn't happen when I apply the brakes while I am backing up, though. Has anyone else had this happen with so few miles on their vehicle?
  2. MegansPrius
    MegansPrius GoogleMeister, AKA bongokitty
    2,437
    27
    Chicago, IL
    <div class='quotetop'>QUOTE(warcat @ Sep 4 2007, 06:02 PM) [snapback]506999[/snapback]</div>
    You might want to look at the Toyota Service Bulletin in this thread:
    http://priuschat.com/TSB-BR001-07-Brake-ac...ise-t30143.html
    EDIT: warcat, gbee42 and hobbit are both much more technically savvy than I, so I would advise you to try their solutions first before giving any consideration to the service bulletin.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The rear brakes are drums, which self-align when backing up. That will account for them not making noise in reverse. Try cleaning off the rust by using the friction brakes on an open piece of road. Shift into N and give the brake peddle a firm press. Repeat this a couple of times and see if they sound any better.
    Tom
  4. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    In the Prius, the rear brakes self-adjust [if needed] any time the
    hydraulic cylinder activates. They're a little different. See
    this analysis for the lowdown.
    _H*
  5. qbee42
    18,058
    3,074
    Northern Michigan
    <div class='quotetop'>QUOTE(hobbit @ Sep 5 2007, 12:04 AM) [snapback]507145[/snapback]</div>
    Wow, hobbit, that's an amazingly elegant method of adjusting the drum brakes. I like it.
    Tom
  6. warcat507
    17
    <div class='quotetop'>QUOTE(qbee42 @ Sep 5 2007, 08:24 AM) [snapback]507264[/snapback]</div>
    I went to the dealership this past Saturday. They cleaned the brakes & that seems to have taken care of the problem. Doesn't surpise me that they needed cleaning. Up here in the Texas "Pothandle", a lot of the roads are more suited to four-legged horsepower :)
  7. warcat507
    17
