Brakes frozen then ok after reverse. Rain related?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by CoryMacMahon23, Feb 8, 2025.
  1. CoryMacMahon23
    CoryMacMahon23 New Member
    Hi all, when I shifted into drive today my brakes were locked up so the car was barely moving. When I put it in reverse the car moved normally, and worked fine after putting it in drive again.
    The yellow brake light with the parentheses has been going on and off.
    This may be due to recent rains, me not driving for 5 days and the brakes possibly rusting.
    Planning to drive 120+ miles tomorrow though, so I wanted to get a second or third opinion on whether anything else could be going on that I should look out for.
    Thanks
  2. ChapmanF
    17,349
    Yes, the shoes could have gotten stuck in position during the wet-weather non-driving, and knocked back into position when you reversed.
    If you have time and nice weather before the 120-mile trip, you might get out the jack and take the rear wheels and drums off, and just sneak some grease under the shoe edges where they touch the backing plate. You don't have to remove the shoes or undo any springs to do that; it's easy to pry a shoe away from the backing enough to sneak a screwdriver in with a blob of grease on the blade. Don't get any grease on the braking surfaces of the shoes or drums.
    The shoes have definite little stamped areas on the edges that rest on little raised areas of the backing plate; those are the only places they touch, to be greased.
    If your backing plates are rusty, those support areas probably stand out with a lighter shade of rust.
    #2 ChapmanF, Feb 9, 2025
    CoryMacMahon23, Brian1954 and MAX2 like this.
  3. MAX2
    MAX2 Senior Member
    1,436
    483
    101
    Third planet from the Sun
    If I were you, I would inspect the condition of the brake drums inside.
    Brakes are a responsible part of the car and you need to be sure that the brakes are in order.
    I had a case when one of the springs on the rear drums jumped off, which led to the wheel locking.
    It's good that this was not on the road, but near the house.
    I inspected, installed the spring, added grease, assembled.
    CoryMacMahon23 likes this.
  4. CoryMacMahon23
    Thanks to both of you for the feedback. I ended up not driving and will follow your advice in looking into this issue. Much appreciated!
    Brian1954 likes this.
