Brakes / interesting thing happened on the way to the Forum
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by ETP, Oct 19, 2016.
  1. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,802
    1,170
    Auburdale FL
    My daughter has my 2011 Prius and noticed that when she pushes the brake pedal to the floor at a stop light that it locks the brakes on for 4 secs. She was adjusting her seat belt.
  2. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    That is normal - it is not a bug, but a feature - it helps the car stay "in place" when starting from an incline. You press the brakes "hard" for 3-4 secs, you hear a beep, the car stays in place without applying the brakes long enough for you to press the accelerator to start.
    In the Gen4 the function is automatic, meaning that if the gyroscopes in the car detect an incline, the car will come to a stop, without applying the brakes.
    grape808 and RCO like this.
  3. ETP
    2,802
    1,170
    Auburdale FL
    Cool beans
  4. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Gyroscopes???
    Whatever it is, it does work pretty well.... Sometimes.
    Two times I tried it, my car started sliding back slowly. :eek:
    Other times, I had success and the car held.
    grape808 likes this.
  5. bisco
    51,994
    wait, did you drive that car for 4 years?:p
  6. pakitt
    2,173
    1,313
    Colorado
    Gyroscopes, yes. They are used to understand the position of the car on the 3 axis. The information is used by the traction control to understand if the car is e.g. sliding or rotating and apply brake accordingly to keep the intended direction of travel (as per steering wheel position).
    So far it seemed to be working fine on all grades I ended up being waiting (traffic light or traffic only).
  7. Coast Cruiser
    2,267
    2,571
    Pakitt, what is that loud "bang" I hear when a wheel slips on a wet surface?
    Is that the traction control kicking in?
    I was driving slowly both times, when it happened.
  8. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Butting in here, but could it have been the metal plate itself rocking on the road surface. They can make one helluva clatter!
  9. pakitt
    2,173
    1,313
    Colorado
    That's the ABS
