brakes make a groan/croak whenever I let go of them
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Panagiotis Garbis, Mar 28, 2021.
  1. Panagiotis Garbis
    Panagiotis Garbis Junior Member
    22
    Chicago
    I have a 2015 Prius - 36k miles
    whenever I let go of the brakes, there’s a little bit of a groan/croak sound that comes out. I’m in Chicago and it’s colder and it’s been raining lately I don’t know if that has anything to do with it. Don’t know if the rust here has anything to do with it.
    The car was originally from Florida In not sure if that info is useful.
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Rust will cause noise
  3. ChapmanF
    15,569
    Does it sound like it's coming from the wheels (or some of them)? Or from behind the firewall where the brake pedal is?
    If from the wheels, probably a bit of light rust down there. May go away on its own with use, or respond well to a simple inspection and some sandpaper in more refractory cases.
    If from the pedal area, it may be what others sometimes call the grunt, bark, or honk. For 2010s and early 2011s there was a firmware update for that. A 2015 probably has the updated firmware already. Next move if it's honking can be to give the actuator air bleed procedure a try.
  4. Panagiotis Garbis
    22
    Chicago
    I ju
    I hear it more so whenever I am parking, when I am driving I don’t hear it. I can record a video tomorrow if that helps.
  5. bisco
    49,446
    yes, that would help. sounds more like the pedal area to me.
  6. Panagiotis Garbis
    22
    Chicago
    the brakes just sound dry whenever I let go of them - I don’t know if that makes sense. It won’t let me upload a video file.
  7. bisco
    49,446
    try cleaning the rotors by getting up to 30 mph or so on a quiet road. throw it in neutral, and gently apply the brakes. see if the noise goes away or changes, repeat as necessary. rust usually comes off pretty quick, mine is gone by the time i back out of my garage into the street, but i do it every day.
    Panagiotis Garbis likes this.
  8. Panagiotis Garbis
    22
    Chicago
    you are the 2nd person to suggest that - sounds good, will do! I don't think the noise sounds like something is wrong per se, just a bit annoying if anything. Thanks for your help!
  9. Panagiotis Garbis
    22
    Chicago
    bisco,
    Could I email the video of the sound to you? It won't let me paste it on this thread. Let me know
  10. bisco
    49,446
    you might need moderator approval, i asked for help
  11. Panagiotis Garbis
    22
    Chicago
    Your idea worked - the sound is much less evident and I don't hear it as much as I did as before! Thank you!
    Do I do this every day?
  12. jerrymildred
    jerrymildred Senior Member
    11,508
    14,110
    Tampa, FL
    I can't remember when I've had brakes that didn't groan when I let them off a little slowly.
    I've heard of people doing it. I don't do it, but I don't live in the salt kingdom.
  13. ChapmanF
    15,569
    I do it whenever I notice brake noise. No noise, I don't do it. It's such second nature by now I hardly even notice myself doing it when I do it. It usually ends up being after the car's been parked overnight in a long soft rain. Pretty much guaranteed embarrassing brake noises in the morning.
  14. bisco
    49,446
    as needed
  15. Panagiotis Garbis
    22
    Chicago
    thanks for the feedback everyone
