Brakes make a weird farting/squirming noise
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by xunkn0vvnx, Sep 10, 2008.
  1. xunkn0vvnx
    xunkn0vvnx New Member
    29
    After a roadtrip from Southern California to Northern California, I noticed my brakes make this weird farting noise that I can alter depending on how I pump my brakes at a standstill. Anybody experience this? and if so, can you shed some light on my situation? Thanks!
  2. blamy
    blamy Member
    380
    Central Florida
    Man; talk about about a straight line!!!!
  3. _echo
    _echo Junior Member
    83
    Orange County
    Awhile back, there was a TSB on this. I don't remember the TSB information, but dealers have given me strange looks when I asked about it.
    If I remember correctly, the TSB called out steps starting from purging out the actuator with fresh brake fluid, to actual replacement of the actuator assembly. (It's been a LONG time since reading it, so I'm not really certain about any of this!) Note that to do this type of work, you either need a recommended scantool and the service manual, or time at a dealer. Prius is not like the olden days where you just attached the bleeder bottle and pumped on the brakes!
    I actually hear this in my car when the car has been cold soaked. (Ermm. ok.. cold for me!) That's any time when water outside isn't liquid any more!
  4. Patrick Wong
    18,200
    6,472
    If you were to characterize the noise as a squeak, then the attached TSB may be of interest. Note that brake system performance is unaffected by the presence of the noise.
  5. sbunin
    sbunin NYC Prius Driver
    NY
    I've had a similar issue but I only notice it in cold weather when I am pressing on the brake. It doesn't happen when I am in park. I'm going to run this by my repair shop. Thanks for the PDF
  6. mchlmrtz
    mchlmrtz New Member
    22
    Hey. That happens to our Prius every time we go up to Big Bear in the winter. I'll have to ask about that TSB next time I take it in for service.
  7. mchlmrtz
    mchlmrtz New Member
    22
    Darn. I see that the TSB is only applicable if the car is with the 36 month/36,000 mile warranty. I'm past that already.
  8. richard schumacher
    7,663
    1,038
    United States
    [another idiot post deleted]
