Brakes or B mode
Discussion in 'Gen 2 Prius Fuel Economy' started by etyler88, Dec 1, 2005.
  1. etyler88
    etyler88 etyler88
    450
    Dover, DE
    I know this has been discussed many times but it usually gets too technical for me. Which makes more regen .cars on MFD screen when I come to a stop light.
    Assumption, 1/4 mile of distance to stop & I'm going 50 mph; I will have to use the brakes no matter what.
    Should I:
    A - go into B mode as soon as possible and stay off brakes till very end or
    B - not use B mode at all and brake normal?
    C - not use B mode at all and brake light then hard?
    D - other
    Which will make the most regeneration?
    Please keep answers simple, A, B, C or the other
    Thanks
  2. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    My understanding is "B".
  3. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    The short "non-technical" answer is do not use the B mode at all. If your comming down a long steep hill with a full battery or at speeds under 20 mph it might be OK.
    I would recommend reading the technical stuff, especially some of the posts on this subject by efusco, it really isn't hard to understand and isn't all that technical. I have found that taking the time to understand a little about how the car works has made me a better driver.
    Edit: I should add that making a lot of regen cars is not necessarily a good idea.
  4. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    Jeff, I think your avatar is a strong competitor with maggieddd's. Poor kid...
    But I have to disagree with you about using B. From other posts, we already established that using brakes alone will regen more energy than using B.
    tumbleweed is right. When you regen, there's conversion lost involve in the process.
    The best thing to do is anticipate stops and lightly brake from long distance.
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Ignore B-mode. The situations where it is the best thing to do are so rare and hard to predict and recognize that it's just rarely the best choice and certainly is almost never the best choice in everyday driving.
  6. DieselConvert
    DieselConvert Member
    121
    Central Coast, CA
    If B mode (not choice B, above) really just simulates conventional transmission downshifting, then it is simply a convenience to avoid alternate braking and unintentional accelleration from coasting downhill. If, on the other hand, it really "engages" the Internal Combustion Engine to impede gravity acceleration, the potential for recapturing energy for recharge of the battery is lessened. Who knows the exact mechanism by which the B position of the selector lever accomplishes its retarding action? Sorry, this obviously doesn't simplify, as etyler requested, but I, too am confused - I have seen other posts that do not clarify it for me.
  7. San_Carlos_Jeff
    871
    160
    Northern California
    2012 Chevy Volt
    We're in agreement. My "B" was choice B in the original posters message. Choice "B" is to not use B. Confused yet? :blink:
  8. NuShrike
    NuShrike Active Member
    1,378
    B.
    How's this, B-mode keeps the engine on which does waste some gas.
    Train yourself to use the brakes instead. Think of B as brakes++.
  9. davedog
    davedog Member
    403
    SF Bay Area, CA USA
    yeah dont use B mode
  10. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    OH!! I GOT IT :blink:
    No really, I do. :p
  11. tumbleweed
    4,067
    687
    Eastern Oregon
    This is known, some of the people here at priuschat have figured it out for us. All you have to do is find the information. The search function will find a lot of it or you can just look through the various forums at past posts.
  12. Venturer
    Venturer New Member
    79
    If you're a flatlander, you'll probably never need it. If you live in the mountains, you've probably already learned that the "B" is the best friend you have going down a long 8-10% grade like the Jackson side of Teton Pass. In the right situation it is a real brake saver.
    Doug
    P.S. FWIW I believe the B mode regenerates until the battery is full. Then it will turn the ICE over, but with no gas being injected. This bleeds off some power from the battery so there is room for more regeneration. Therefore, it does not waste any gas while decending a long grade.
  13. habel
    habel New Member
    230
    Oslo, Norway
    Interesting. B is usefull here in Norway, we have a lot of slopes hills and mountains.
