Brakes vs regen
Discussion in 'Prime Technical Discussion' started by glenthompson, Sep 20, 2017.
  1. glenthompson
    glenthompson Junior Member
    Williamsburg VA
    2022 Prius Prime
    i live in a mountain community. With my old Prius I had to shift into B on the downhills. On my Prime, I can take some downhills with the brake pedal keeping the regeneration graph at 50-75%. If I’m using the brake pedal but not getting maximum regeneration are the brakes applied any? Don’t want to burn them out on the long downhills but want to get maximum regeneration.
    Qmo likes this.
  2. jaqueh
    jaqueh Active Member
    341
    199
    San Francisco
    Yes your brake pads can be used depending on your speed and how much braking you are requesting even if the regeneration portion of the bar isn’t completely filled. It is hard to judge when friction brakes are being applied as they made it more seamless, but there should be slightly more regenerative braking power than the gen 2.
    Also if you are in ev mode and switch to b, it will only use regenerative braking depending on your state of charge.
  3. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    Non-owner question: shouldn't up to 100% regen on the graph be no friction pad braking?
  4. jaqueh
    341
    199
    San Francisco
  5. bisco
    49,490
    a scan gauge will show how much friction braking is being used.
  6. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
    What setting is used on the ScanGauge to make that determination?
  7. Trollbait
    11,560
    Likely under the Xgauge functions that need to be programed in.
  8. VTBIGDOG
    211
    146
    The reason why I asked is because I looked and I did not see any gauge that existed for that feature
  9. Trollbait
    11,560
