Brakes wearing unevenly
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by The Phoenix, Dec 27, 2017.
  1. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    I have a 2008 and it has 260,000 on it I bought it with 189,000. The left side brake pad and rotors are really worn and make a terrible noise when I brake and now even when Im just driving. The other side looks "ok". I do know they are not original parts by looking at them I saw the name dura stop on them. I will be replacing them Saturday. My question is why would the left side wear more than the right. Also I thought it could be a wheel bearing, but my mechanic said at 189,000 when I got it the bearings had to be replaced because the wouldn't have lasted that long. If anyone has any ideas about what the problem could be if there might even be one I would appreciate any feed back thank you 20171220_160530.jpg 20171220_160619.jpg 20171220_160646.jpg 20171220_160719.jpg
  2. Patrick Wong
    18,200
    6,493
    The left brake caliper is sticking which caused excessive brake pad wear.
    Raytheeagle, valde3 and MickyMatter like this.
  3. Dxta
    Dxta Senior Member
    1,932
    769
    Lagos
    Patrick has given you the major reason y that happens.
    MickyMatter likes this.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    The left side is down to the wear squeelers. There to alert you theirs no more pad left.
    Whoever replaced the pads never greased the slide pins. Your looking at new rotors too or maybe enough meat left to get them cut..
  5. Mendel Leisk
    40,589
    Check the caliper slide pins, these are what allow the caliper to move freely laterally. They need periodic relube, and verfication the sealing boots are still pliable, doing their job. Sil-Glyde Brake Lubricant is one product suitable for relube. It has the appearance of vaseline or silicone dielectric compound.
    When the pads are out you can verify caliper slide pins are still working as they should, by just gently shifting the caliper side-to-side: it should move fairly freely. If it doesn't you'll get uneven wear, drag.
  6. Dxta
    Dxta Senior Member
    1,932
    769
    Lagos
    ..and the major reason y the pins gets sticky in there, is because of corrosion that has developed overtime, from unreplaced brake fluid. Brake fluids are hygroscopic (absorbs moisture from the environment).
    Ensure you get a brake flush done on the car before replacing another sets of pads/rotors. Not having a flush done to take care of any moisture in the brake system would compromise the slide pins again in future.
    Ensure the slide pin boots are inspected for failure. A torn boot, would allow the introduction of water/ice in the path of the pin(s).
    PS: Have also experienced some I stances where the caliper pistons get stucked. Reason? Corrosion in there.
    Dxat
    #6 Dxta, Dec 27, 2017
  7. edthefox5
    10,096
    4,831
    Clearwater, Florida
    I don't think the brake fluid has anything to do with the corroding slide pins. Fluid never touches the pins.
    They corrode from lack of lube and extreme heat. Extreme heat creates lack of lube lol.
    I had a front caliper get stuck on one of my Crown Vics I had just bought. Rolling down the road I smelled something burning and the car started pulling to the left hard all of a sudden. I knew exactly what it was too lol. By the time I pulled over which was quick the tire was smoking.
    No extinguisher in the car it would have burned to the ground. In a big car its no joke when a caliper gets stuck. Very exciting.
    Autoway in Florida will not flush the brake fluid. I asked for it they turned me down.They were seeing too many ABS failures. None of the dealers in there network flush g2 brake fluid. Oh they'll drill the sh*t out of you for a brake job but wont flush it.
  8. Dxta
    Dxta Senior Member
    1,932
    769
    Lagos
    You were very lucky. But y would they shy from a brake flush? Maybe they just scared flushing a Prius or what?
    Like I did say in my post above, asides the caliper pins getting stuck, the caliper pistons too sometimes get stuck because of ruptured piston boot that hasn't being noticed. What do you think about that?
  9. edthefox5
    10,096
    4,831
    Clearwater, Florida
    They say the flushing damages the ABS module. The service advisor I talked to at this very big dealer knew about all the Prius issues. They see alot of Prius.
  10. padroo
    padroo Senior Member
    2,763
    2,251
    It's not worth cutting rotors, I would replace them with new ones and if the caliper doesn't retract easily replace it and the hose.. You have a lot of miles on it and these things don't last forever. I always replace the hose with the caliper after getting burn too many times in the past.
  11. Dxta
    Dxta Senior Member
    1,932
    769
    Lagos
    They must be scared.
    Brake flushing on the Prius, or hybrid cars have got procedures. They may just not have that time, but it sure has being done.
    So, what happens if your car, for instance, has got lots of mileages on it, and the fluid in there has stayed more than 2-3 years? Take the car to another dealership that understands that there's a need to flush, or just drive em until the brake components develop some fault?
  12. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    I have this problem too (uneven brake pad wear). I noticed it when I switched to my winter tires. I'm at 90k and will probably have to put new pads on in the next 20k. Here's a short video on how to fix:
    I will say the two times I changed brake pads on other cars, there was always at least a little bit of difference between the two sides. On a Prius this means your brakes might only last 100k instead of 120 or 150k :rolleyes:. Granted, I've never owned a car with less than 60k and probably never will. Seems inevitable on an older car that the slide pins loose their lubrication and get corroded, especially when on a Prius where they might only get new lubrication every 100 or 150k.
    Looking at the pics, it looks like your left rotors are damaged from the brake pads wearing off and metal on metal contact. However your right rotors look okay from the image. In most cases you'd want to replace the rotors as a pair, so you may well need a new set.
  13. Mendel Leisk
    40,589
    Toyota USA says to do brake service every 3 years or 30K miles. That would include pin lube.
  14. Dxta
    Dxta Senior Member
    1,932
    769
    Lagos
    That's what I'm saying too!
  15. Kevin_Denver
    581
    425
    Denver, CO
    Mendel, interesting that you mention this, considering you posted this previously: Prius brake service recommendation - from a Toyota service manager | PriusChat
    I agree a service every 30k is ideal, but considering a set of pads is only ~$30, it's hard to justify. I just inspect the brakes yearly when switching out winter tires.
  16. Mendel Leisk
    40,589
    It's not ideal, just spec.
    Dxta likes this.
  17. edthefox5
    10,096
    4,831
    Clearwater, Florida
    My car is 10 years old never touched the brakes or fluid.
  18. Mendel Leisk
    40,589
    And you're proud of that? :confused:
  19. Patrick Wong
    18,200
    6,493
    For Prius, I would not worry about brake fluid replacement until the brake actuator assembly is replaced.
  20. valde3
    valde3 Senior Member
    2,002
    746
    Finland
    Why? Old brake fluid can cause your calibers and wheel cylinders to leak and/or not return and some other problems as well. Changing the brake actuator won’t fix those.
