Brakes: what anti-seize type?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by andreimontreal, Oct 28, 2019.
  1. andreimontreal
    andreimontreal Active Member
    326
    107
    28
    Montreal
    Is copper anti-seize recommended or bad for Prius brakes?
  2. spiralhelix
    spiralhelix Active Member
    255
    216
    Illinois
    I guess it really depends on where you want to use it. I use silver myself to keep hub/rotor/wheel from corroding And seems to work. I don’t think copper would be “bad”, but I’ve just never thought about. I just go straight to silver. Just keep it off the lug threads, it can cause over-torqueing.
    I use disc brake lube on the back of the pads , pins and sliding shims. Some might say to use Toyota lube. I’ve used ultra disc lube without issue.
    -Spiral
  3. Mendel Leisk
    38,720
    I had a can of Permatex silver anti-seize, replaced with the same. Decades with Honda, when dealership brake service was done, I'd see either silver or copper squeezing out around brake pad shim edges. Sil-Glyde brake lubricant is what I've been using for caliper pin lube and boots.
    There is anti-seize in this pic. I don't lay it on thick, and always apply it to the piece going on, the smaller of the two, and that way you get it just where it's needed:
    (Replacement rear brake pads/shims on ours, after I screwed up the caliper orientation.)
    frodoz737 likes this.
  4. ASRDogman
    ASRDogman Senior Member
    6,089
    3,273
    This is what I have used for years. No problems.
    Just make sure you clean off all the old stuff first. You want it as clean as possible.
    And don't over use it. Enough to coat the parts is good.
    If you torque the bolts for the caliper, you don't "need" and locktite. Though some new bolts
    come with it already installed.
    Most people are overly careful with the brakes. :)
    andreimontreal likes this.
  5. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    Back when I was doing breaks they were trying to glue the break pads to Caliper.
    We had this one car that would make noise no mater what anti squeal they had on the market. So I put some normal grease on the back of them.... Yep fixed never saw car again.
    I think any high temp grease would do trick.
  6. Mendel Leisk
    38,720
    Some blue goop that set up? I remember something like that. Never went that route.
  7. ASRDogman
    6,089
    3,273
    Maybe the brakes fail aaannnnndddddd........... NO! Just kidding....
    I've taken them apart, except for removing the puck, and wire brushed everything.
    Cleaned all the bolts, re-lubed and greased everything to finally get rid of the noise.
    Even told someone to turn the radio up louder! :whistle:
  8. Raphael Muscarelle
    661
    222
    Then they had some orange stuff. After that incident I always just greased back of pads. Don't know why industry thought glueing them to Caliper would do anything.
  9. Raphael Muscarelle
    661
    222
    Lol
