Braking, Turning right, Slight bump = Clicking from front L wheel.
Discussion in 'Prius v Technical Discussion' started by Crunch, Oct 15, 2012.
  1. Crunch
    Crunch Junior Member
    NC
    Twice I have made this happen going to 'Wendys'. It is a right turn at about 5 mph, there is bump from blacktop to pavers. I have my foot slightly on brake during turn. Then the front left wheel emits this rapid clicking noise until I nearly come to a stop.
    I am not that impressed with v steering feel at all. Posting another post on steering 'clunk' during right turn. have been back to dealer twice. they can't see anything wrong. Am about to ask for rep to get involved and take him/her to Wendys, and not for lunch!
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,967
    4,710
    Texas Hill Country
    You might have engaged the anti-lock brakes. Usually you can feel a pulsing in the brake petal at the same time. Remember you can take it to another dealer if you are not satisfied with the first one.
  3. BZzap!
    BZzap! Senior Member
    1,607
    877
    There is a TBS out for a clicking noise when going over a bump or those little road reflectors. It comes from the brake caliper pins and bushing clearance. Depending on the year of your Prius, the bulletin recommends replacement of the pins and bushings in the front brake calipers. After 20011 models it downgrades the repair to just greasing the pins and bushings. At my first oil change I have already scheduled this to be done. The Bulletin is T-BS 0136-11
  4. Former Member 68813
    3,524
    981
    US
    Did you figure out the cause for that? I have that issue in hatchback.
