1. Rugged_Rowan
    Rugged_Rowan New Member
    Southeast
    2025 Prius
    Hey so new the community, just recently picked up a 4th gen 19’ Prius LE, curious on what coolant you guys put in yours?
    51,155
    welcome!
    toyota
    Rugged_Rowan likes this.
  3. JC91006
    16,674
    8,519
    The coolant is good for at least 100k miles, are you needing to change it? You can use any of the premixed pink asian fluids. Walmart has it for about $12 a gallon
  4. Mendel Leisk
    40,587
    Have a look in the Owners Manual: it specs the coolant and says alternatives are ok if they meet a LIST of criteria. To be fair I understood some of the words in that list, but a lot were incomprehensible. I got this from Toyota dealership parts department:
    Toyota Super Long Life Coolant
    you’ll likely need two gallons. My 3rd gen experience (will verify in a bit) was approx 1.5 gallon (aka 6 qts) for engine coolant, at replacement. For inverter maybe 0.75 gallon (aka 3 qts).
    If Owners Manual is missing, pdf version can be downloaded from Toyota Tech Info site, in the “manuals” tab.
    #4 Mendel Leisk, Apr 3, 2025
  5. Rugged_Rowan
    Southeast
    2025 Prius
    oh no, I was just curious cause i noticed that it needed to get topped off.
  6. Rugged_Rowan
    Southeast
    2025 Prius
    good to know! thank you!
  7. JC91006
    16,674
    8,519
    Instead of paying $30 for a bottle of Toyota coolant to top off, you can get it free when you do you next oil change at the dealership. Just ask them to top off the fluids, it's free
