Brand New Hybrid Battary Cells
Discussion in 'Prius PHEV Plug-In Modifications' started by 4hybrid, Mar 26, 2012.
  1. 4hybrid
    4hybrid New Member
    Irving, Texas
    Anyone knows where to get new hybrid battary cells for the 2004-2009 Prius.
  2. jdenenberg
    jdenenberg EE Professor
    3,852
    1,852
    Trumbull, CT
    2020 Prius
    LE AWD-e
    New ones are not generally available.
    You can buy low mileage modules (6 cells each) that come from Prii that were totaled in an accident. They are available on eBay and the modules from 2010+ Prii are slightly improved over the 2004-2009 Modules.
    If you are trying to repair a failing Prius battery, you need to learn how to charge and balance Prius modules so that your repair lasts a while. Please take care to protect yourself as a Prius HV battery has sufficient energy to cause injury.
    JeffD
  3. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    115
    Nothing new
    However if in USA try
    -local salvage yard
    -ebay
    -xvipers
    -autobeyours
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    And, you need them because??? You trying to convert yours into a PHEV by using the above?
