Brand new Optima battery keeps dying
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by red04prius, Dec 21, 2019.
Tags:
  1. red04prius
    red04prius Junior Member
    17
    Atlanta, GA
    Background:
    • Bought my 2004 Prius in 2014 at 186000 miles.
    • I am currently at 272000 miles.
    • Don't know when the 12v battery was last changed by previous owner.
    • I used it for 5 years in relatively warm Atlanta and never had an issue.
    • Recently moved to Virginia and the car refused to start on a cold morning.
    • It has been at least 5 years since the battery has been changed. So, I replaced it with a Optima battery.
    • No problems for the next few weeks.
    • Then yesterday, the brand new battery died.
    • As soon as I connected the jumper cables with the battery in my other car, the Prius started up with no issues.
    • This morning, the battery died again.
    • Again, as soon as I connect to the other car's battery, it works.
    • I checked the MFD in maintenance mode and the battery voltage shows up above 12v instantly and charges up to 14v with no issues.
    I have now doubled-checked that all lights and other electronics are off. I even pulled out my aftermarket stereo front unit. But it doesn't feel like a parasitic drain issue. It that was the case, I would have had to charge up the battery for a while before the car would start, correct? Instead in both cases the car starts up instantly after getting hooked up to another car's batter.
    Any ideas?
    52,391
    sounds low. they don't always come charged. put it on a smart charger, the car won't charge it properly.
    if that's not the problem, you may have a parasitic drain with the car off.
  3. red04prius
    17
    Atlanta, GA
    Could you elaborate? What should be the voltage readings when the car is parked for a couple of hours and what should it be once I drive it for a few minutes?
    Yesterday after jumping it, I drove for a few miles and it stabilized at 14.3v or somewhere around that. Seems to me that it is fully charged at that point. Then why would it not start the next morning? Thanks in advance.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    You need a voltmeter to check the actual battery voltage while things are not working.
    The 14.x reading you got indicates that the charging system is working right.
    Unless there is a loose connection at one end of the main battery cables, this looks like your new battery has failed.
    That is not too uncommon for the Optima's.
    Their high owner rating has dropped a LOT lately.
  5. bisco
    52,391
    if you're using the mfd to read the voltage, it should read at least in the mid 12's, because there is some load on it, and a fully charged new battery ought to be close to 13 volts.
    at 12 volts, when you try to start the car, the extra load is probably dropping below the acceptable computer parameters.
    as sam mentions above, 14.3 when 'ready' is the charge from the inverter going to the battery, not the battery itself.
  6. audiodave
    audiodave Active Member
    800
    272
    US
    I trickle charge my optima once a week. Prius charging system to weak to keep up. Especially since I run a 5 channel amp off it.
    edthefox5 likes this.
  7. Mendel Leisk
    41,905
    This.
    Let the car sit overnight, preferably with hood popped, because even just opening a door to pop the hood will drop voltage slightly. Not that much though, maybe 0.1 volt. Then connect the voltmeter (should be digital) red lead to the jump point, under the hood:
    And connect the black (negative, aka "common") lead to a bare metal or bolt, on the car body or engine.
    This will give you the battery's "voltage", without the car either drawing it down, or running it up. The at-rest voltage. Which is something. Better than nothing.
    But still not the full picture. For that an electronic load tester is good. Any automotive retailers selling batteries (including the retailer you bought from, if it was local), should have a pro-level tester of that type, and be willing to check it for free, give you a verdict on it's condition. Dealerships will do the same but likely want some compensation. You can also get yourself something like a Solar BA9, and DIY.
    I'd suspect the "verdict" will be good, but in need of recharge. If that's the case, a smart charger, around 3.5 amps:
    A CTEK 3.3 charger would be playing it safe, though I think you good get away with a CTEK 4.3, in particular with the Optima. I probably have the same battery on my 3rd gen, and that's what I'm using on a regular basis, in the "snowflake" mode (slightly higher voltage, suitable for Optima YellowTops.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Your not setting the car alarm every night. That will catch 95% of every light left on as it will not arm if light left on. Or at least before going to bed look at the car. See if any lights left on.
    In the meantime 3 things
    1—A car battery will never ever output 14 volts. Your seeing the battery charging voltage the inverter is sending to the battery.
    Has nothing to do with the battery’s capacity,
    You want to see what the battery voltage is in acc mode your missing a step In the mfd routine. In accessory mode the car is not on.
    2—Do whatever you can to fix this ASAP and stop jump starting it as that had proved fatal for many G2s over the last 10 years. Especially if your jumping it directly to the battery in the trunk. There’s safe and handy jump point under the hood.
    3—If forced to jump make sure the donor car is off as there will be a large inrush of current if battery really bad. Engine off will minimize inrush current available. And use the front jump point.
  9. OptimaJim
    OptimaJim Member
    74
    Wisconsin
    You can measure a parasitic draw, but you cannot “feel” a parasitic draw. Your car either has a draw or it doesn't, but unless you measure it, there's no confirming it, although aftermarket stereo systems often go hand in hand with increased parasitic draws. Fully-charged, your battery should measure about 13.0-13.2 volts. If you don't feel comfortable measuring your parasitic draw directly, you can also fully-charge and completely disconnect your battery from your vehicle. It should hold close to that voltage for 12-24 hours afterward.
    If it holds voltage when disconnected, but loses voltage when connected, then something in the car is discharging it. If it doesn't hold voltage when disconnected, then the battery has an issue and needs warranty service (contrary to sam's opinion, that would be very uncommon for a new battery).
    Whenever any battery is discharged to the point that you need to use jumper cables or a jump box, you should make sure you fully recharge your battery with a battery charger as soon as possible. Relying on your vehicle's charging system can lead to a cycle of dead batteries and jump-starts, until either the battery or charging system fails. We always encourage folks to treat jumper cables or jump boxes like they would a one-gallon can of gasoline. They can get you out of a tight spot in an emergency, but you'll probably be headed to a gas station very soon after to fill the tank. You should do the same with the “electrical tank” in your battery.
    Jim McIlvaine
    eCare Manager, OPTIMA Batteries
    http://www.pinterest.com/optimabatteries
  10. bisco
    52,391
    just to clarify, there is always a drain in the prius. so a measured drop while connected is not an indication of a defect.
    a parasitic drain would be higher than toyota's spec. if you cannot dive that deep, it's easy enough to just put a volt meter on the jump points every morning. if the battery held overnight while disconnected, the daily drop should be miniscule.
    the easiest place to start is by fully chrging the battery. that may solve your problem without further testing
  11. red04prius
    17
    Atlanta, GA
    Thank you all for the replies. I have three questions:
    1. Is it not possible to recharge a dead battery back to full simply by driving long enough? Or is charging using a battery charger a better option? If so, why? I am asking because I would like avoid buying a battery charger if possible.
    2. I googled to understand the difference between a standard battery charger and a trickle charger but still not quite sure which one is more appropriate for my situation and a Gen2 Prius. I do understand trickle chargers will do it slower and that fast charging can be dangerous. But then why does anybody buy standard chargers? Also it seems some chargers do not stop charging even when the battery is fully charged, which I believe is bad? So should I get a charger that auto-stops?
    3. Every time I have tried to jump the battery from the front jump point under the hood, it hasn't worked. As a result, I have always had to jump the actual battery. But, based on edthefox5's reply, that can be 'fatal' to the car? How exactly? Does it damage the 12v battery or does it do even worse, like damage the hybrid battery?
    Thanks.
  12. sam spade 2
    7,035
    2,804
    2017 Prius c
    Done right, there is no real danger.
    Ed has a tendency to exaggerate sometimes.
    And he goes completely off the track sometimes too.
    Done wrong, all kinds of bad things can happen.......and the point of connection makes no real difference.
    Given that your jump effort works in one place but not the other is a STRONG INDICATION that you have a bad main battery connection somewhere......and the point where the negative cable connects to "ground" at the body or frame is the most likely suspect.
  13. red04prius
    17
    Atlanta, GA
    Thank you sam spade 2. Costco is selling this:
    https://www.costco.com/battery-tender-4amp-smart-battery-charger-and-maintainer.product.100519712.html
    Any idea whether that is a good one to buy?
    Also, I installed the new Optima battery myself while watching an DIY YouTube video. It maybe that I did not connect the negative cable to ground at the body properly. I am going to go check that now. But could that explain why the battery is losing charge? It doesn't seem like it because the ground shouldn't have anything to do with holding charge, right?
  14. sam spade 2
    7,035
    2,804
    2017 Prius c
    Yes that would be an excellent choice but the most common size is 2 amps at about $15 less.
    It is possible that you misunderstand the situation.
    The battery might not be CHARGING properly due to a loose connection.......or due to a defective battery........or due to a failed charging system. It may not be "losing" an abnormal amount of charge at all.
    And finally, the connection of the main negative cable to ground is NOT something you would normally visit while installing a new battery.
    Where did you get your new battery ?
    If it was "mail order", you now might have to spend the money that you thought you saved to pay a real mechanic to find and fix the problem.
  15. red04prius
    17
    Atlanta, GA
    I now understand. I will take it to a mechanic and get the installation checked. Thanks.
  16. bisco
    52,391
    it has been said that it takes 8 straight hours for a prius to charge the battery. that may not be an across the board rule for all prius and batteries. optima may take longer, but i'm not sure. it might be worth a try if you have the time.
    supposedly, you don't have to drive it, just leave it ready in a safe place.
  17. dolj
    dolj Senior Member
    8,559
    4,349
    Wellington, New Zealand
    If the battery is completely discharged, try 16 – 20 hours.
  18. red04prius
    17
    Atlanta, GA
    Got the battery tested at Advance Auto today and it came out at 259 CCA while the full capacity is 450 CCA. This is after I jump-started it to drive it there and the drive was around 5 minutes. Tomorrow I am taking it to a mechanic to see if my DIY installation of the new battery was correct and whether there is a parasitic drain.
    I have also ordered that battery charger from Costco. That is arriving a few days later. I will provide an update once I resolve the problem.
  19. Mendel Leisk
    41,905
    That's not good; time to start shopping I think. Does Advanced Auto have batteries? Maybe best to stick with a local retailers.
    Maybe Optima's quality is taking a dive?
    I installed this in September of 2015. Reading 12.73, and CCA 517, checked it just now:
  20. bisco
    52,391
    where did you buy the optima? try pm'ing the fella in post #9, he's the man
