Brand New with Leaking Differential - NOT TRUE!
Discussion in 'Gen 2 Prius Main Forum' started by PriusOwner004, Sep 11, 2007.
  1. PriusOwner004
    PriusOwner004 New Member
    191
    Just had my first oil change and the guy said to schedule an appointment with service because my differential is leaking. He said, I quote: "I know it's new, but some of them come with a leaking differential. Sorry."
    Needless to say, the guy next to me who was talking to me about my Prius and considering buying one, suddenly lost interest when he heard that...
    Anyway that happened to anyone else? 5 thousand miles only :-(
    [EDIT]
    Updated information starts in post 16.
    Jump ==> http://priuschat.com/index.php?s=&show...st&p=511493
    [/EDIT]
  2. David Beale
    David Beale Senior Member
    5,963
    1,983
    Edmonton Alberta
    Even the odd Toyota will have something that needs to be fixed. Mine has been trouble free. Nothing to be worried about. Just keep snickering at the cars that -always- leak a little diff. fluid. BTW, the Prius is on or near the top of the list of no-problem new cars.
  3. PriusOwner004
    191
    If I wanted a leaky car I would've bought a Lamborghini, damn it! lol
    Oh well!
  4. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi PriusOwner004,
    But the Prius, like all front wheel cars, does not have a differential case. If anything is leaking its the engine or the transmission. Because the gears that are normally in a differential case (at the rear of the a rear wheel drive car) are inside the transmission case.
    Drive it home, get a clean peice of carboard, put it under the car, and check the carboard in a week. Do not let any other car park over the cardboard.
    This sounds like a hoax to hook you on expensive unneccassary maintanence. If nothing is evident on the cardboard, take your car somewhere else for maintanence.
    By pointing out the leak in a part the car does not have, I think he was testing to see if you were gullible.
  5. oly_57mpg
    oly_57mpg New Member
    360
    Olympia, Portland, Seattle...
    <div class='quotetop'>QUOTE(PriusOwner004 @ Sep 11 2007, 05:06 PM) [snapback]510802[/snapback]</div>
    Yes, but they are famous for fuel leaking, not differential or non-explosive component.
  6. galaxee
    galaxee mostly benevolent
    9,810
    466
    MD
    there technically is a differential case, but it's housed within the transaxle unit. there are a few oil seals in the trans unit, and if installed improperly they can leak.
    just because there is a leak does not mean it is serious enough to drip under the car though, seepage also occurs and can indicate a very minor leak. at any rate, the car is under warranty at 5k and will be covered as such for the repair.
    that's why they provide that warranty in the first place. don't worry about it too much. and be glad they pointed it out to you in the first place. some dealerships won't even tell you, if it will add to their warranty repair numbers...
  7. jamarimutt
    jamarimutt New Member
    985
    <div class='quotetop'>QUOTE(David Beale @ Sep 11 2007, 04:52 PM) [snapback]510793[/snapback]</div>
    My 2004 had the steering assembly replaced at 46,000 miles. The ABS failed slightly earlier. The MFD has been working erratically for over 20,000 miles. The car has 68,000 miles... I don't think I'll reach 80,000 with it.
  8. cairo94507
    cairo94507 Active Member
    923
    36
    Auburn, CA, USA
    I would do the cardboard too. I would also jack the car up, use jack stands, and look under the car yourself and see what you see. The car is under warranty so if it in fact is leaking, take it back to Toyota, get a loaner, and then come back and get your fixed 2007. No worries; all cars have their little problems.
  9. cairo94507
    923
    36
    Auburn, CA, USA
  10. PriusOwner004
    191
    Service says a few new ones came that way. Wondering if it has happened to anyone else.
  11. PriusOwner004
    191
  12. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Where's it leaking from? The drain plug? The joining seam? The
    axle seals toward the back? It's pink fluid, right? Pictures??
    _H*
  13. hobbit
    4,089
    468
    Bahstahn
    _H*
  14. PriusOwner004
    191
    Like another member here said, it's under warranty, so I am not paying anything.
    It's possible it's something else leaking. I don't blame the guy. He just does oil changes for the dealership and was kind enough to point out that there is a leak. He said it MIGHT be the differential and that I should have service check it out. So I'll find out tomorrow. Let's hope it's not a big problem.
    And I'm sorry about that guy above who's experienced so many problems with his Prius. There are bad apples everywhere, but I certainly hope my car isn't one of them! I've never had luck with cars. Every car that I've had from my first car $600 to my last one (before the Prius) $110K - all have had issues and all have leaked. My luck, I guess.
    Hmm, I've never heard of fuel leakage in Lambos, but they ARE notorious for oil leaking. Same with Corvettes. My neighbor doesn't park his 05 Vette in his drive way or his garage because he doesn't want it all messed up from the oil... LOL
  15. PriusOwner004
    191
  16. PriusOwner004
    191
    Hold on to that. I am not 100% sure it's the differential. Oil guy said it MIGHT be the differential. Going to service tomorrow and I'll post details. Thanks.
  17. PriusOwner004
    191
  18. Godiva
    Godiva AmeriKan Citizen
    10,339
    I third the cardboard thing.
    And at least if something is wrong it is covered under warranty.
    No problems with mine. Purchased April 2005.
  19. Godiva
    10,339
  20. Godiva
    10,339
    No matter what they say, I'd get a second opinion from a different dealer. Who knows how much they really know about the Prius. That "a few new ones come that way" sounds fishy to me.
