Break fluid change
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Asif Subhan, Jan 13, 2019.
  1. Asif Subhan
    Asif Subhan New Member
    South Carolina
    I
    I know that Prius manual recommend DOT 3 oil change , but is it okay to use DOT 4 instead of DOT3 ? Or should I stick with DOT 3?
    Prius with 200K
  2. ChapmanF
    15,563
    Wikipedia says it's ok "if the elastomers in the system accept the borate compounds that raise the boiling point."
    I would avoid guessing about the elastomers, and just use DOT 3. If it were me, I'd probably even buy the fluid at the dealer, or at least check their price. I thought their engine oil would be overpriced, but it turned out not to be.
  3. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Should be fine
  4. Asif Subhan
    South Carolina
    I
    Thank you guys , will definitely call dealer . My dealer had deal last time , 42 dollar for oil change including labor and oil filter . I’m wondering how much a gallon of engine oil would cost at dealer. I normally use Mobil 1 ep or Mobil 1 high mileage
  5. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    Hack jacked your own thread on 4th post
  6. Mendel Leisk
    38,706
    Agree, don't get clever, and to avoid any compatibility issues (real or not), just stick with Toyota brand
    I used Toyota DOT 3 fluid, purchased through dealership, for $7 something (CDN) per "pint". I bought two pints, which worked out.
    I'm getting liters of Toyota 0W20 in bulk at dealership for $4.90 (CDN) per. Bottled liters of same are about $6 now I think.
