Break gen 2
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by anko, Jan 2, 2022.
  1. anko
    anko New Member
    Hungary
    Active
    Prius generation 2
    The car breaks by itself. It has happened several times that the car breaks by itself usually after I started the car and stopped shortly ( went into a shop) and started it again.
    After it breaks by itself at low speed, I stop the car, restart it then it works fine.
    Any ideas what I should check and repair?
    Thanks in advance for advice.
    #1 anko, Jan 2, 2022
  2. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Do you have any OBD2 codes that you can share?
    FYI : you're moderated until you've posted 5 times
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Can you clarify if you mean brake or break?
    edthefox5, ydpplqbd and SFO like this.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,218
    5,902
    Columbia, SC
    Sounds like the car transaxle may be in B mode instead of D. May want to verify you have the car in D, or that the shifter isn't going bad and putting itself into B mode. Or maybe you're brushing against the shifter by accident and causing it to go into B made. I've done that one myself twice in the last year or so.
    SFO likes this.
  5. anko
    anko New Member
    Hungary
    Active
    Yes, it is brake, sorry.
    I did not change the car from D, that is 100% sure. I remember seeing the red sign just when the brake comes on.
    I will check out the code.
  6. bisco
    49,433
    that means there are trouble codes that need to be read by an appropriate prius scanner.
    when you say it brakes, is it coming to a complete stop on it's own with your foot on the go pedal?
    ydpplqbd likes this.
  7. anko
    anko New Member
    Hungary
    Active
    yes
    bisco and ydpplqbd like this.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    Is the parking brake on lol?
  9. Mendel Leisk
    38,705
    By this do you mean, when you take your foot off the gas pedal, it slows down too quickly, like the brakes are on?
  10. bisco
    49,433
  11. bisco
    49,433
    could a bad skid control ecu do that?
  12. anko
    anko New Member
    Hungary
    Active
    no:)
    Hi!
    No, I mean that I drive and it does not slow down but brakes. I did not take my foot off the gas pedal.
    But it has happened about three times during the last month.
    A couple of seconds after starting the engine so I did not reach high speed.
    I just restart it and the problem seems solved. (for some time)
  13. Mendel Leisk
    38,705
    Is it then an odd slowing down, even though you're pushing the gas pedal? Like the car is suddenly dragging some weight behind?
  14. ChapmanF
    15,562
    In that case, this is a highly unusual report, and it would be very interesting if you could get access to Techstream (or to any on-board diagnostics tool with data logging capability) and log the brake fluid pressure readings, to actually capture the application of the brakes while you are driving.
  15. anko
    anko New Member
    Hungary
    Active
    Thanks a lot!
    I will try.
  16. anko
    anko New Member
    Hungary
    Active
    YES:)
  17. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
    Caliper piston stuck? Very common on hybrids because of lack of use.
