break light out
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by hjohnson919, Jan 12, 2012.
  1. hjohnson919
    hjohnson919 New Member
    Washington state
    My dealer wants to charge me $274.83 to completely replace the whole tail light assembly because the rear passenger break light is out. :( Is this really necessary just to replace a light bulb? (2004 Prius)
    49,455
    no. and welcome to priuschat! have you tried replacing the bulb?
  3. Patrick Wong
    18,200
    6,472
    The brake light is composed of six LEDs, so if that has failed then the entire assembly must be replaced.
    If some other light is out, that would be an incandescent bulb which can be separately replaced.
  4. guyinmarin
    guyinmarin New Member
    Marin County, California
    I
    My independent repair shop also told me recently that my left brake light needed replacing and since it was LED's I would need to go to the dealer. The replacement assembly supposedly costs $275 or so plus labor. They thought Toyota might do something for me since it was so expensive.
    Anyone had any luck complaining to Toyota??
  5. bisco
    49,455
  6. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Try ebay, adoptapart.com, or autobeyours.com. Since most total-loss cars in junkyards are front or side impacts, a large number of them have intact brake/taillight assemblies. Or buy new for $150 a piece from online parts counters like partznet.com. Note that 04-05 ($150) are different from 06-09 ($170).
    I totally believe a $275 dealership quote, between paying MSRP plus the the labor for the installation. It is reasonable, given the constraint placed on the dealership due to the high cost of the part.
  7. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Re: brake light out
    +1 on finding a used-but-good replacement.
    I got a pair from autobeyours.com a few years ago, quick response too. :thumb:
  8. hjohnson919
    Washington state
    Could a complete novice do the replacement herself if she bought the part online?
  9. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
  10. labumm
    labumm Junior Member
    57
    My break light LEDs are dim. All regions have the same brighness. Reaching in through the access hole and jiggling the wiring does not change the brighness. Possibly a problem with a driver board? Or are these just 6 LEDs in series?
    I am also having intermittant problems with the tail light (bad electrical contact--probably oxidized crimp connection in socket), so it will make sense to remove the interior panels to gain access to the wiring harness to fix the intermittant. (I replaced the tail light with an LED module 6 months ago because I got tired of the tungsten incads burning out.)
    My questions are:
    Is there anythng fixable with the break light LEDs?
    If I buy a new tail light asembly, is the wiring harness included (bulb sockets + connector)?
  11. hormosapiens
    hormosapiens Junior Member
    44
    north Jersey
    hi all.my brake light was working 5 out of 6 than a week ago it all went out. So after reading around I just bought the left side assembly for 2004 gen2. It arrived today from Tawian made from DEPO. But there is a big problem with it. The Parking light block inside the assembly is moving around. its not fixed in its place like the reverse light or the left turn signal. What were your experiences with these aftermarket tail light? any favorite brand? I am returning it.
    thanks
