break pedal squeek
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MR.K, May 3, 2009.
  1. MR.K
    MR.K Junior Member
    86
    Idaho
    brake pedal noise
  2. dogfriend
    7,512
    1,185
    Carmichael, CA
  3. MR.K
    MR.K Junior Member
    86
    Idaho
    Sorry ...hit the wrong click ...anyway I have a seal chirp when I step on the brake pedal and found the TSB on it ....Just started at 29500 mi. ,it's an 07 .. I'll try the brake bleed first ...thanks
  4. jdenenberg
    jdenenberg EE Professor
    3,852
    1,846
    Trumbull, CT
    2020 Prius
    LE AWD-e
    You need special software in a OBD2 diagnostic unit to control the hydraulic valves/pumps so a dealer is your primary option to bleed the brakes. If a third party opens the bleed valve, you are likely to have to go to a dealer to get your brakes to work right.
    My dealer would have charged me $90, but I had a brake inspection done for $30. When the d(st)ealer tried to burn me for an unnecessary $500 full front brake job, he bled the right front brake to repair the "Chirp". $30 total cost.
    JeffD
