Bridge power down
Discussion in 'Gen 2 Prius Main Forum' started by Festus, Aug 21, 2006.
  1. Festus
    Festus New Member
    38
    In Seattle, we have quite a few drawbridges, which can delay drivers for several minutes at a time. When coming to a stop at an opening bridge, can I assume that the ICE will shut off on its own? Or is it smarter to go ahead and turn off the power button while waiting?
  2. ramarren
    ramarren New Member
    96
    San Francisco Bay Area, California
    <div class='quotetop'>QUOTE(Festus @ Aug 21 2006, 09:13 AM) [snapback]306730[/snapback]</div>
    The ICE will shut down on its own automatically. If I'm going to be sitting in stopped traffic for an extended period, I hit the Park button so I don't have to hold the car with the brake, that's all, and let the power system do its thing to keep the climate control running and the music/hands free phone going.
    Godfrey
  3. RichBoy
    RichBoy New Member
    189
    Just drive and operate the car as you noramally do, let the Prius do the work, it will and in the most effiecient manner.
  4. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    I wonder what the effect would be on mileage, the difference between turning the car off and leaving it on while stopped for a while? On one side if you are using AC or heat, or even have the headlights on, the ICE will run eventually to recharge the battery. If you turn the car off you won't have any drain and the ICE, of course, won't run. But if you power down and then restart when you are ready to go won't it need to go through stages 1, 2, and 3 again? It should get through stages 1 and 2 fairly quickly because it will already be warm, but to get into stage 4 you still have to stop in stage 3 for 5 or 10 seconds. Most likely better just to leave it on.
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    If you don't need the AC and you know you'll be stopped completely for at least 10 minutes or so then I might consider shutting down. If it's less than that or might be less than that I'd probably leave it in Ready mode.
  6. keydiver
    keydiver New Member
    509
    Hobe Sound, Florida
    Interesting question, I just had this happen to me today. For me, it all depends how hot it is outside, and whether I want to take the mpg hit. Today, it was a little cooler, and breezy, so I shut the car off and wound the windows down while I waited, and I was very glad I did. They opened the drawbridge WAY too early for a big barge going about 2 knots, and I was stuck there for >10 minutes. :angry:
  7. Stilview
    Stilview New Member
    61
    Northern VA
    10 minutes or so? Leave it on with the AC or heat (whichever is applicable). Depending on conditions before the stop, there will be plenty of battery.
