Bridgestone Air-less Tires
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Oct 9, 2014.
  1. bwilson4web
    16,010
    Original title and source: Bridgestone Sucks the Air Out of its Tires
    In effect, the 'radial springs' of the Bridgestone tire are engineered for specific spring constant and hysteresis. In contrast, air inflated tires have a balloon structure that depends upon the spring and hysteresis of the sidewall and tread belt. Inflated tires have fewer engineering options to optimize stiffness needed for turns, a lateral impulse, because the tires also have to deal with bumps and object, a radial impulse load.
    I'm looking forward to the Bridgestone results.
  2. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
  3. mrbigh
    3,686
    699
    Long Island, NY
    How we will be doing to keep them clean and out off road debris?
  4. drash
    drash Senior Member
    2,553
    1,297
    Upstate NY
    Gives a new meaning to "mud in your tire".
  5. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    and for those of us who are NOTengineers: ;)
    Definition of HYSTERESIS (Websters): a retardation of an effect when the forces acting upon a body are changed (as if from viscosity or internal friction); especially : a lagging in the values of resulting magnetization in a magnetic material (as iron) due to a changing magnetizing force.
    Wikipedia: Hysteresis is the dependence of the output of a system not only on its current input, but also on its history of past inputs. The dependence arises because the history affects the value of an internal state.
  6. Trollbait
    12,346
    I imagine when these airless tires finally make it to the mass market they will have a simple rubber covering for that. This could also solve a problem with the Tweel was initially reported. These are noisier than current tires. Some of the noise could be in the spokes flexing, but their required shape may also cause air turbulence and thus noise.
  7. wjtracy
    wjtracy Senior Member
    11,360
    3,606
    Northern VA (NoVA)
    ....oh the poor spiders living in there. Well at least it'll put and end to the N2 in tires threads.
    bwilson4web and austingreen like this.
  8. bwilson4web
    16,010
    Remember, this is a developing technology close to this stage of aviation technology:
    Testing is what will lead to product.
    Mr. Bubbles likes this.
  9. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    Those guys are bicycle mechanics. And hacks at that!
    That thing will never get off the ground.
  10. Ashlem
    Ashlem Senior Member
    754
    502
    WI
    2017 Chevy Volt
    Hmm, looks interesting. They're probably going to cost a lot more than the regular tires though, since these probably won't need to get replaced as often. Still, at least they're trying new things.
  11. MarcSmith
    MarcSmith Active Member
    471
    150
    Northern VA
  12. Mendel Leisk
    40,575
    I'm still in awe of tubeless tires, lol.
  13. El Dobro
    El Dobro A Member
    7,075
    3,258
    The Air lobby will never let it happen.
    telmo744, bwilson4web and ftl like this.
  14. PhilWray
    PhilWray Member
    82
    28
    Malaysia
    Off-world use:
  15. MattNiem
    MattNiem Junior Member
    52
    Finland
    Do they mention anything about rolling resistance?
  16. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    I'd be very interested in test results while under more intense performance, handling reviews, etc. For instance, how do they react during an evasive maneuver, or even just hitting a bump while going around a curve at speed.
    I'd also like to know temperature-range and aging effects. All of these are existing considerations for standard tires.
    These have been under development for years, which may be an indication of either unresolvable design issues or economic hurdles.
  17. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Naive owner: I broke a spoke. Can I just replace it ?
    PriusChat: NO NO NO. Disassemble the wheel and balance all the spokes, then reassemble as a fractal.
    ftl and drash like this.
