Bridgestone Ecopia 422 Plus tire pressure
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by priusmatty, Feb 22, 2021.
  1. priusmatty
    priusmatty Active Member
    304
    108
    Louisiana USA
    2020 Prius
    L Eco
    My 2020 L ECO came with the newest Bridgestone Ecopia 422 Plus tires. I like them so far. What pressure do you keep your LRR tires at? I keep them 42 psi all around. Your opinions please? Thank you.
  2. Tyfly
    Tyfly Member
    65
    94
    I have the same tires and I run them at 42-43 PSI.
    priusmatty likes this.
  3. priusmatty
    304
    108
    Louisiana USA
    2020 Prius
    L Eco
    Ok great, thanks!!! Do you like them? So far, they have been great for me, even in rain.
  4. priusmatty
    304
    108
    Louisiana USA
    2020 Prius
    L Eco
    Also, do you use nitrogen?
  5. Tyfly
    Tyfly Member
    65
    94
    I like them so far. I’ve put about 40k on them.
    I do not use nitrogen, air works just fine for me. Plus it’s free.
    alanclarkeau and priusmatty like this.
  6. priusmatty
    304
    108
    Louisiana USA
    2020 Prius
    L Eco
    Ok thanks. How do you find their traction in the rain?
  7. Tyfly
    Tyfly Member
    65
    94
    Pretty good I think, just remember that with a higher tire pressure you will lose some wet weather traction because the tire has less contact with the road.
  8. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    Nitrogen is generally thought to be a waste of money - besides, you can get mostly nitrogen in an 80% blend free. It's called air.
    Unless you've got a Jumbo Jet or similar - and drive at stratospheric heights - forget it.
    priusmatty, Mendel Leisk and Tyfly like this.
  9. Mendel Leisk
    38,735
    A couple of pounds over the recommendation on the drivers door decal, at most. I set all four the same too.
