Bridgestone Ecopia EP20 wear?
Discussion in 'Gen 3 Prius Fuel Economy' started by niteryder, Jul 2, 2013.
  1. niteryder
    niteryder Junior Member
    39
    Earth
    On my 2012 I still have the OEM tires. What life should expect out of them? I commute 80 miles per day and run them at 42/40 psi. They have also been rotated ever 5k as recommend.
    I have 26k miles on them and they are wearing even, but they seem to be wearing faster then what I would expect.
  2. tach18k
    tach18k Member
    406
    38
    SoCal Beach Area
    On my 2012 oem Yoko's and need tires real soon, I also think I need new pads. I'm at 42,000 miles
    Richard Fish likes this.
  3. Former Member 68813
    3,524
    981
    US
    Incidentally I also have 26000 miles on EP20 and they look similar if not slightly worse. I typically get 30,000-40,000 from OEM tires, so this is expected. OEM tires are usually not long -life.
  4. MPGnutcase
    MPGnutcase Active Member
    579
    114
    Chicago
    Yes the OEM tires are made to be cheaper if you bought the same brand and model at a tire store they are better and last longer, the car Mfg. specs are to buy the tire at a CHEAPER price for Bridgestone takes out some of the good and costly stuff out of the tire..................... nice ugh
  5. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I can't see the inside of your tire but judging by by what I do see, you have less wear in the center than the outside of the tire. Seems like you can even out the wear by pumping up your tires a bit.
  6. alanwagen
    alanwagen Member
    121
    79
    FORT WORTH
    2018 Prius
    I have over 50K miles on mine. I may be able to get 60. I am looking to replace them with the same. I checked with Firestone and the EP20's are more fuel efficient than the EP 422's
    Regards, Alan
  7. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    why would you check with firestone. do they make the ep20?
  8. Former Member 68813
    3,524
    981
    US
    Let me guess, mostly Hwy?
    City driving gets roughly half of miles vs hwy driving. Cornering is brutal on rubber.
    Not sure about the efficiency difference.
  9. Steve terry
    Steve terry Member
    217
    Oklahoma
    I have the same tires. I just looked on Tirerack.com for tread life and it has none. Looks like I could get 40 or 50,000 miles. I hope so. I keep mine at 38 but plan on upping them to 40,42.
  10. Slick26
    Slick26 Junior Member
    40
    Twin Cities, MN
    Bridgestone bought Firestone, so same company now. But Firestone has stores/shops, Bridgestone doesn't.
    So they probably checked with a Firestone shop. Either way, same difference.
    I know I'm late, but I was reading this thread and figured I'd clear that up.
  11. jlupton
    jlupton New Member
    Wow, these are great pictures in terms of texture and tread depth. The tread is still great in the center, but is thin on the outside of the tires. This means you are wearing it down faster in that section. The cause: taking turns at a speed that is too fast for your car. That's why they're wearing down so much there. It happens with my tires too. I don't like it, but that's most likely what it is.
  12. Slick26
    40
    Twin Cities, MN
    I'm officially at 62,000 miles with original EP20's. They're toast. I'm basically just stretching them out as long as I can until I order winter tires, which will be very soon. If I can get these tires into November, or even December, before finally putting my winter tires on, I'll be happy.
    Windows Phone ?
  13. daveabitz
    daveabitz Junior Member
    Rio, WI
    What winter tire do you use?
  14. Slick26
    40
    Twin Cities, MN
    I haven't used any on the car yet. Last winter my stock tires were ok, but not great. I'll probably go with nokian hakkapeliitta's this winter. I've heard great things about them.
    Windows Phone ?
  15. Steve terry
    Steve terry Member
    217
    Oklahoma
    I have 28,000 on my EP20's and they are close to the end of life. May get another 7,000 if I am lucky. But winter is coming so may be better to buy new tires soon.
  16. Slick26
    40
    Twin Cities, MN
    Definitely. Don't want to mess around on slippery roads with bald tires.
    Windows Phone ?
  17. Mendel Leisk
    38,648
    Do you have separate rims, or are you planning on getting them? It's a good strategy, there's a corolla rim that'll work.
    I would get the snows sooner than later, for a couple of reasons. Later, they may sell out, and/or the shops are crazy busy. Also, you do NOT want to get caught out in snow with near-bald EP20's.
  18. Slick26
    40
    Twin Cities, MN
    Yeah I know, I've been doing this awhile.
    I wasn't planning on a separate set of wheels this winter, but will probably do it eventually. I did it on my wife's SUV the past few years, and it worked out great.
    Windows Phone ?
  19. Savalife
    Savalife Junior Member
    Baltimore, MD
    How does Bridgestone Ecopia EP20 compare with Bridgestone Ecopia EP422? Has anyone had experience with a Michelin Primacy MXV4(H) on a 2011 Toyota Prius
  20. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    I replaced mine at 41k miles. It was to the point where it was dangerous to drive in the rain (hydroplane at 60mph) even though I'm sure I can squeeze another 5k miles before i get to the tread wear indicator. Now I have Continental Pure Contact and I love them!
