Bridgestone Turanza at 90k
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by yeldogt, Nov 5, 2014.
  1. yeldogt
    yeldogt Active Member
    810
    313
    NE
    Well ........ actually 93K .. I will have the Prius V 3 years next January .. we passed 93K and the original 17" Bridgestone's still have tread above the wear indicators.
    Looking through the threads on tires ... the V with the 17's are not mentioned much. The Turanza EL-400's have obviously been good .. I get almost 60 mpg in the summer .. so do I just replace them?
    Tirerack has them for $173.00 each.
    Any others with different 17's?
    Other then normal oil/ filters ... nothing has been done to the car. I did replace a bulb!
  2. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Holy crap. My Toyo Proxes A20s are at 3/32nds at about 45k. I dont think they will make it past 50k. I plan on going with Bridgestone Ecopia EP422s in the 17 inch size.
  3. yeldogt
    810
    313
    NE
    Car has been given a workout -- lots of highway miles. I have been happy with the Bridgestone's -- predictable tire. I was surprised with the 280 tread wear rating on them. Toyota does not install LLR tires on the Prius with 17's ... not sure why? Other then a test drive I have never driven the standard Prius with smaller wheels ... so I can't compare the ride or the handling/ grip with LLR tires that some have. The Bridgestone Turanza EL 400-02 don't get the greatest rating on Tirerack .. and the OE Toyo's are quite a bit more money.
    My fear with the LLR tires: They all get a bad rating is the wet weather. We get a lot of rain in the Mid - Atlantic. I don't want to risk any wet traction loss. We regularly got mid 50's MPG on the tires and one member get above 60mpg -- so no problem with no LLR's on this Prius.
    The Kumho Ecsta is less then a $100.00 and gets very good ratings
  4. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    If you value wet traction, you probably want Michelin Primacy MXM4.
  5. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    What kind of tire pressure did you run in the EL-400s?
    Generally, highway miles are easier than city miles on tires. My work has a couple of security Priuses to patrol the parking lots and from what I am told the tires are shot in 20K crawling around at 20MPH!
  6. wjtracy
    wjtracy Senior Member
    11,360
    3,606
    Northern VA (NoVA)
    ...don't push it...we just had a fender bender on wet slick roads the day before our new Tire Rack tires were scheduled to be mounted. I did not think the tread was that bad, was just trying to beat winter. OK we got the TrueContacts on there now.
  7. yeldogt
    810
    313
    NE
    I used the recommended pressure per manual with the Bridgestone's... nothing special. Rotated with each oil change -- 10K
    After some more looking and a call to Tirerack -- picked the Michelin Premier AS SL . $635 delivered and a $70 rebate. They have a good rating in the rain and are the newest design.
  8. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Please keep us posted on the MPG. I have looked hard at those but am afraid to take a big MPG hit.
  9. bisco
    51,142
    i hope they work out as well as the turanza's, never heard of anything like that before.(y)
  10. yeldogt
    810
    313
    NE
    Got them installed .. they are new .. so I expected they would be quieter .. they are. So time will tell ... They have a higher tread life rating and also more of a LRR tire than the Bridgestone .
