BRIGHTER INTERIOR BULBS
Discussion in 'Prius v Accessories and Modifications' started by dave34, May 14, 2014.
  1. dave34
    dave34 New Member
    2013 Prius v wagon
    Are there any bulbs brighter than OEM for the dome, map and rear compartment lamps?
    I've tried LEDs and the blue is unacceptable.
  2. xliderider
    xliderider Senior Member
    7,872
    3,116
    Honolulu, HI
    I've installed LEDs like these. They have that warm glow just like the incandescent bulbs without the bluish color of the normal LEDs, but they are brighter:
    Link 1
    Use these for the hatch and dome light positions: Link
    bigrin likes this.
  3. B2FiNiTY
    B2FiNiTY Active Member
    979
    226
    I'd say go with LEDS. Get at least 5000K "super white". None of that blue stuff.
  4. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    Gotta ask: how the heck does that fit into the dome lights or hatch light?
  5. xliderider
    7,872
    3,116
    Honolulu, HI
    The panel is flat, it is placed between the plastic lens/cover and the internal bulb holder. There is an adapter on a wire that goes into the place where the regular festoon bulb would go.
    SCH-I535
    bigrin likes this.
  6. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    225
    Harrisburg, PA
    I've been there, done that with the pep boys and eBay led lights. Osram Sylvania makes an LED 194 bulb which retails for about $13 each on the shelf but they can be found cheaper online. They are called "LEDriving" and don't get hot like the cheap ones. Also they can be put in the socket both ways! Normally LEDs have polarity.
  7. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
  8. fatdawg
    fatdawg Member
    131
    55
    Bay Area, CA
    2014 Prius Plug-in
    I bought a White LED kit from a seller on ebay yitamitor for about $17, very happy with the kit. They originally sent me the wrong color (bluish) which they exchanged.
    Here's a pic if the difference with pure white and xenon white.
  9. bigrin
    bigrin Junior Member
    59
    Ann Arbor, Michigan
    2014 Prius v wagon
    Big Thanks to Xliderider for the link and info. Just ordered a set. Can you advise what type of bulbs you would recommend for replacing the lights in the doors of my Prius V three? Thanks in advance. cr
