Brightness adjuster not working
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by aleew7, Jan 13, 2022.
  1. aleew7
    aleew7 New Member
    Washington, USA
    2016 Prius c
    I bought a 2016 Prius C3 in April and have used the dashboard/speedometer brightness adjuster dial many times since then. Today I tried to use it and nothing is happening. I tried this while on, moving and stationary. I have my headlights on the lowest setting (the one that turns on and off with the car) like I always do, and in the past the adjuster has worked while they are on this setting.
    The only work I’ve had done on my car since I bought it was that someone smashed my driver’s side window so I had to get it replaced. For about a week after it was replaced the window rolled down automatically when I rolled it up (unless I only rolled it up in tiny increments) but that issue went away on its own for whatever reason - could that be related, like a wiring issue?
    Thank you!
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    You have a bit of a misunderstanding here.
    There is no "automatic" setting for the headlights. Well, except that if you do leave them ON, they will go off after a few minutes.
    The "lowest" setting is all lights OFF, where the dash dimmer does NOT work.
    The next click up is DRL......where the dimmer does not work either.
    The dash dimmer only works with headlights or "parking" lights ON, which is the 3rd and 4th position.
  3. ChapmanF
    15,619
    The window has a don't-crush-my-arm feature programmed in, where if it is moving up and hits something, it stops and rolls down.
    That, of course, can't be the whole story, because every time you roll it all the way up it hits something: the top of the door! If it didn't know better, it would hit the top of the door and say "oops" and roll back down.
    ... which is exactly what it does until it learns where the top of the door is.
    When the window is replaced, it has to learn that again, and until it does, it behaves the exact way you described.
    The process for teaching it the top of the door is roll it slowly up as you were doing and hold the button there for a bit. When that issue "went away on its own for whatever reason", I'm going to say that you unknowingly hit that combination right one time when you were rolling it up.
