brightness of the main screen
Discussion in 'Newbie Forum' started by baysidefish, Sep 18, 2021.
  1. baysidefish
    baysidefish Junior Member
    33
    usa
    2021 Prius
    LE AWD-e
    When I turn on the headlights, the main screen dims. I do not remember what I did. Now it does not dim anymore.....................any ideas? thanks
  2. fuzzy1
    10,150
    There should be a scroll wheel to adjust dash light brightness at night. To leave it at full brightness with the headlights on, turn the wheel all the way up until it stops, then push a bit harder until it clicks. That should snap the dash to full brightness.
    At least, that is how it works on older generations, I can't verify on Gen4.
    jerrymildred likes this.
  3. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    It's the same on the Gen 4. But if you turn the brightness control till it clicks, the instruments and display will not dim with the headlights on at night.
    The wheel is left of the steering wheel and low, kind of where it is on most of the cars I've owned over the years.
    #3 jerrymildred, Sep 19, 2021
    fuzzy1 likes this.
  4. baysidefish
    33
    usa
    2021 Prius
    LE AWD-e
    yes, it works....thank you all very much
