Bringing a Prius back from 4+ years parked
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Vgk, Aug 8, 2023.
  1. Vgk
    Vgk New Member
    Utah
    Hello guys!
    I have been reading a lot on here and everyone seems very helpful! First off let me say I am new to Prius’s but am very good with cars. I got a Prius that’s been sitting for 4 plus years. I have no idea the condition of it as I took it in on a trade for something else (didn’t invest more than $200 on the trade). It’s a 2005 that was last driven in 2018 or 2019. It’s got a completely dead dash currently. The power button flashes red and the check engine light comes on. I have never got anything to come on the dash. The door locks aren’t working and neither are the headlights but the wipers and turning signals work.
    Things I have done-
    Replaced 12v battery with new one. The old one was dated from 2015 so I just bought a brand new one. It’s installed.
    Replaced the fuse block under the hood- might be called the fusable link. The one with the clear cover. It was blown so I had to replace the block. It is currently getting 12.6 to the jump point under the hood.
    Replaced the battery in the key fob- there is 3 key fobs for some reason in the car so I replaced them all. I have also messed with the key button under the steering wheel.
    Replaced the hybrid battery with a known good battery. After I did that I got the car to start one time but the dash was still dead and nothing else worked. I tried to put the car in gear but it wouldn’t go anywhere. Left it started for about 20 minutes then turned it off. Tried to start it again in about an hour but the power button only flashes red and it won’t start any more.
    I also checked all the fuses in the cab under the steering wheel. In the engine compartment fuse block I have checked all but the lower fuses as I ran out of daylight. Let me know if you guys have any ideas! Tomorrow after work I’ll finish checking the fuses and make sure I still have 12.6 to the fuse box. I’m also going to double check the AM2 fuse.
  2. Vgk
    Vgk New Member
    Utah
    Also, tomorrow I’ll try and scan the code. I couldn’t get it to read it when the light was flashing red.
  3. Vgk
    Vgk New Member
    Utah
    Update: had a couple minutes before I went to work. Still no start. AM2 fuse is not blown. But I checked 12 v battery voltage and it’s at 11.8. I’ll charge it when I get home and try again
  4. mr_guy_mann
    mr_guy_mann Senior Member
    3,966
    1,914
    NJ-USA
    You will want to use a capable scantool to check all 15 (or so) systems on a Gen2 Prius.
    Here's a thread that reviews several scantool apps and devices. Several can perform complete system scans and access codes and data for everything.
    Having a "dead" dashboard is a common problem that's usually a failed capacitor on the Combination Meter circuit board. There's a sticky thread at the top of the Care & Maintenance forum about it. This can affect the car turning on.
    Also test all fuses - see which ones have 12V power (on both sides of each fuse).
    Does the power button turn anything on at all? Can you turn on the clock or radio (accessory power?) I would replace AM2 fuse anyway and check again.
    https://priuschat.com/index.php?posts/3290690
  5. Vgk
    Vgk New Member
    Utah
    Went to exchange the 12v battery today and they had to order one. It will be here tomorrow though. I have an obd2 tester so I’ll do a hybrid battery test when I can but the problem is my scanner won’t connect to the car since I can’t get it to turn on. Hopefully the battery fixes that and I’ll check all fuses tomorrow along with replacing the AM2
  6. Vgk
    Vgk New Member
    Utah
    Also I'm wondering if this needs to be in the care and maintenance/ troubleshooting section. Does a mod have to move it there for me?
  7. Tideland Prius
    16,445
    Up to you.
    Yes, we’ll have to move it for you if you wish.
  8. Vgk
    Vgk New Member
    Utah
    If you could move it for me that would be great. Thank you.
    Update: put the new battery in. Still flashing red when I try and start it and dead dash. Checked the rest of the fuses and I had 2 blown ones. ETCS and Dome. Replaced them both and I’m glad to have the dome lights back. Maybe the ETCS is the reason I couldn’t drive it when I did have it started but I can’t even get that far now. I’m thinking maybe it is the combination meter. Is there any work around to that? Can I pull a fuse or anything like that to give it a try and see if that is it?
  9. JohnPrius3005
    JohnPrius3005 Active Member
    423
    234
    California and Hawaii
    Your HV bat might be low. It’s pretty easy to access the terminals to check - look up installing a grid charger.
    If the HV bat is low, say below 200v, build yourself a grid charger and charge the HV bat. It’s quick and cheap to build and to hook up.
    without good volts on the HV bat the ICE cannot be started.
  10. Vgk
    Vgk New Member
    Utah
    Update:
    HV battery voltage at 212
    12 v battery at 12.6
  11. JohnPrius3005
    423
    234
    212 should be ok, although its marginal in my experience with neglected cars. In your shoes I would charge up both. And you might find there is a little dance to do with the power button whenever you disconnect the 12v bat. Some disagree about this so it may depend on what faults you have. Mine requires pushing power on once, waiting 30 sec then pushing and holding the power button until the ICE starts. My cars typically sit for 6 months+ all the time. They all eventually start
  12. Vgk
    Vgk New Member
    Utah
    I put the back of it back together after changing out the 12 v and hv battery. I’m going to start working on tearing into the dash this weekend to get the combination meter fixed. The more I read on it the more it seems like that’s my problem
  13. bisco
    51,155
    no luck with scanning codes?
  14. Vgk
    Vgk New Member
    Utah
    No luck with scanning codes. I can’t get the Prius to go into standby mode or start so my scanner won’t pull the codes. I have the dash all apart and the combo meter out but I’m beginning to wonder if that’s the problem. With the combo meter out and the push to start and key fob thing plugged in it still does the same thing- flashes red and I can hear a relay click on and off. That’s it
  15. Vgk
    Vgk New Member
    Utah
    Any thoughts? This thing is stumping me. I think I may send the combo meter in anyways since I’m this far into the dash and already have it out.
  16. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    That's a good idea as it's not a question if it will fail, but when. A preemptive strike here would be prudent.
    As a side note, when the CM fails to start – the usual failure mode – it should not prevent the car from starting or indeed driving, you are simply driving a car with a dark dash.
    #16 dolj, Aug 16, 2023
  17. JohnPrius3005
    423
    234
    I still say build a grid charger. Then charge both your HV and 12v bat.
    Then reconnect both bats. Put the key fob in the slot, push and release the power button with your foot on the brake like a normal start, wait 15-30 sec then press and hold the power button. You will hear a bunch of relay clicks, and with luck your ICE will start. You may have to hold the power button for 5 minutes or more. This works for me on 3 different Priuses .
  18. Vgk
    Vgk New Member
    Utah
    Is there a guide on how to build a grid charger? Thanks.
  19. bisco
    51,155
  20. Vgk
    Vgk New Member
    Utah
    Not getting any relay clicks after holding power button. If I need to, I’ll build a grid charger. But it seems like 212 should be more than enough to start the car on the high voltage battery. I have found online people being able to start their car all the way down to the low 170s. Also my 12 V battery is brand new and it’s got 12.6 V. Also should be enough if the key unlocks the car with the electronic locks it should be the right key correct? There wouldn’t be a case where the key unlocks the car but doesn’t start the vehicle right?
