Broken antenna removal on a 2012 Prius 2
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rollingm, Dec 21, 2020.
  1. rollingm
    rollingm Junior Member
    Anyone have experience removing the broken off bit left in the roof mount? Thanks
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,957
    4,709
    Texas Hill Country
    Are you talking the screw in part that goes into the roof mount preamp?
  3. rollingm
    Yes I need to extract the broken bit so I can replace with a new antenna. Has anyone successfully removed it with a screw extractor? Any advice? Thanks
  4. rjparker
    7,957
    4,709
    Texas Hill Country
    I have not had to extract that threaded rod but have done so with others. Often it means using a reverse cutting drill bit (left hand bit) to get a starting hole for the extractor. Sometimes the reverse drill bit will pull it out.
  5. ASRDogman
    ASRDogman Senior Member
    6,084
    3,271
    Maybe check an auto parts store, or Snap On for a reverse drill bit.
    As you drill into the broken antenna brass/metal, it will either put a hole in it so you can use an easy out
    to remove it, or the drill bite will catch it and pull it out.
  6. rollingm
    I'll be shopping for a reverse drill bit 1/8 or less Learned something new! Many Thanks
    ASRDogman likes this.
