Broken armrest. Any ideas?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Aaron Vitolins, May 6, 2016.
  1. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Broken arm rest on my 2012 Prius. Not sure how it broke, it's driving me crazy to be honest. If I look in side the door panel (by pushing the arm rest in as far as I can) I see these plastic pieces that are broken.
    The problem is, they don't seem like clips. Just plastic pieces that were melted together in the factory. How am I going to fix this. Any ways of fixing broken plastic? The fix has to be pretty strong becuse when anyone opens the drivers door to get out they push right on that arm rest.
  2. mrbigh
    3,686
    699
    Long Island, NY
    Look through ebay for replacement used parts for cheap
  3. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Couldn't find one. Think I must fix the door panel I have
  4. Rebound
    Rebound Senior Member
    3,972
    2,626
    Portland, OR
    Check Craigslist for someone parting out a wrecked Prius. They all have door panels
  5. Mendel Leisk
    40,574
    Take it right off for a good look. Or at least pop it loose enough that you can get a good look at the back.
  6. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    I broke my arm rest while under 36/36 warranty. Dealer tried remelting plastic clips the first time. It only lasted a short while until it broke again. Dealer replaced the door interior panel this time.
    I have not had any issue since then.
  7. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    I think i will try that. maybe i could melt the plastic back together?? hope i don't die!
    Thank you!
    jdcollins5 and Mendel Leisk like this.
  8. Kenny94945
    Kenny94945 Active Member
    842
    418
    Sausalito
    2016 Prius v wagon
    FWIW
    Melting is worth a try.
    Also Home Depot et al sell plastic specific glues which could supplement the melting to add strength.
    Yes, get the panel off and look.
    Good luck.
  9. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    I agree. Removing the panel is easy and your repair (no matter which road you decide) will be easier overall.
  10. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Thanks guys! Hopefully this week I can get some time to take off the panel. I'll watch a few YouTube videos on it. I took off the panels of my old Prius, surely it isn't much different. I will keep you guys updated
  11. icyrius
    icyrius Active Member
    238
    114
    Florida, USA
    2014 Prius v wagon
    No need to melt them. Just go to Walmart and buy plastic epoxy glue. My son's 2014 had four of them broken from previous owner. I applied two coatings. The first one was just to secure them in place. The second coating was generous to make the joins stiffer.
