Broken down in the mountains
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by EddyKilowatt, Aug 1, 2018.
  1. EddyKilowatt
    EddyKilowatt Junior Member
    My son's hove-to in a turnout on a mountain road with his 2008 (with about 115k miles). VSC, ABS, and Brake lights all went on. Brakes still worked and he was almost to his destination so he cautiously kept going. About a mile later, Check Engine light came on as well as red triangle, and accelerator stopped working. He was able to pull into a turnout (with SMS-only cell signal strength).
    His Scangauge is reading a bunch of codes that don't come up with anything when I search (here or Google):
    P0a86
    C2886
    C2986
    B066b
    B0664
    B0686
    C2186
    C2086
    P0060
    C2386
    B065d
    C1986
    ... and maybe a few more, "the scangauge is being uncooperative".
    12V battery is reading 14V with car on, 12.5-13V with car off. When he powers up the car, the ICE starts and the Check Engine light is on, but the others are now off. He did do an oil change this morning, about 50-60 miles ago. Says all fluid levels look okay right now.
    He's a musician and is on his way to the biggest gig of the summer, which starts in 2-1/2 hours...
  2. JC91006
    16,474
    8,393
    The car is in limp mode, that's why accelerator is not responding well.
    Did he put too much oil in the car? As he's going up and down a mountain, it can really cause a slightly overfill situation into a significant overfill situation.
    The 2008 Prius would take about 3.75 quarts of oil
  3. EddyKilowatt
    Thanks, I'll have him double-check. After an hour or so, the car was willing to re-start, and then was able to drive to destination (and back home after) with no further misbehavior or idiot lights. So immediate crisis over, now we just need to figure out what happened and why.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    POA86 is because the Inverter coolant pump has failed.
