Broken Flywheel Noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TwoPriusInTenn, Aug 26, 2019.
  1. TwoPriusInTenn
    195
    59
    Tennessee
    Does anyone have or know of a video of the noise a broken flywheel makes on a 2010 or 3rd Gen Prius?
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Prob the dreaded engine knocking due to egr circuit being clogged
    Grit likes this.
  3. TwoPriusInTenn
    195
    59
    Tennessee
    Will knocking due to clogged egr disappear with increased rpms/engine speed?
    Knocking on our Prius is happening when the engine kicks in and goes away when the gas pedal is pressed.
    Grit likes this.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    After a few revolutions and TERRIBLE NOISES, it usually gets very quiet. :eek:
    What makes you think about the flywheel in the first place ??
    Grit likes this.
  5. TwoPriusInTenn
    195
    59
    Tennessee
    The noise happens when the car is idling. It also appears to be on the drivers side.
  6. TwoPriusInTenn
    195
    59
    Tennessee
    I have replaced the plugs, coils and injectors. I also cleaned the intake manifold and egr pipe. The egr cooler is so clean, I can see daylight through it! I did clean the egr, but it could be malfunctioning. I have an egr valve on order. It will arrive in a couple days.
  7. TwoPriusInTenn
    195
    59
    Tennessee
    One other symptom I was reminded off. Slight smell like rotten eggs = exhaust and catalytic converter.
  8. tankyuong
    1,555
    660
    Central MO
    My Prius was using coolant and had the same knocking until the crankshaft blew a hole on the side of the engine
  9. TwoPriusInTenn
    195
    59
    Tennessee
    Did it display any codes or other signs, other than knocking, before blowing apart?
  10. tankyuong
    1,555
    660
    Central MO
  11. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Sounds like a head gasket to me... Unfortunately...
  12. TwoPriusInTenn
    195
    59
    Tennessee
    Cause of the problem was a faulty new ignition coil. Replaced with another. Runs smooth.
    Another code flashed up P261B - water pump bad......what are the odds???
    mjoo and Mendel Leisk like this.
  13. mjoo
    mjoo Senior Member
    1,124
    1,316
    Michigan
    Want to update your original thread?
    Pixel XL ?
  14. TwoPriusInTenn
    195
    59
    Tennessee
    Turns out the water pump was seized. Crazy, the timing of that!
