Broken Oil Pan Bolt and Guide Stud
Discussion in 'Gen 2 Prius Main Forum' started by indianballer, Aug 29, 2021.
  1. indianballer
    indianballer New Member
    Merced, CA
    The blue arrow is the broken stud that is used as a guide to place the oil pan then bolt it down. The red arrow is the snapped bolt that is stuck inside the threads. I may have messed up the threads already with a drill bit while attempting to remove the snapped bolt however I am unsure since there were only a few threads exposed. What do you recommend? Will using a bunch of RTV prevent oil leaking?
  2. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
    Remove the broken bolt and if needed, re-tap the hole and put in a new bolt?
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,487
    1,588
    NJ-USA
    Myself, I would use a small grinding stone in a Dremel tool to make a divot in the center of the broken fastener. Then drill slowly with a new 1/8" bit to make a pilot hole. If it is centered then go up to whatever size for tapping the threads. Also see what a helicoil kit goes for.
  4. Mendel Leisk
    38,763
    Might find something in this:
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Wow are you running maple syrup for oil? That's pretty bad there.
