Broken Rear Spring
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by osiris12, Mar 8, 2014.
  1. osiris12
    osiris12 Owner of 3, yes three priuses
    119
    Upstate NY
    Hi All,
    I just brought my 2006 Prius in for a yearly inspection. They told me that the rear spring is cracked and I should also do the struts and total 4 wheel alignment.
    Total price without tax, $741.00
    Needless to say, I'm taking it somewhere else.
    The new price quote is $140 per strut with spring and $80 labor each, totaling $440 plus tax.
    That's still a lot but better then $741.00
    My 2006 has 143,000 miles. Guess it was time
  2. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Rear spring with crack highly unusual. Have some one else look at it before having "work" performed.
  3. Patrick Wong
    18,200
    6,474
  4. frodoz737
    4,297
    2,348
    33
  5. osiris12
    119
    Upstate NY
    I'm getting a second opinion this coming Saturday.
    So the coil spring is part of the rear strut assembly, right?
  6. Patrick Wong
    18,200
    6,474
    Yes, although the rear is called a shock, not a strut.
  7. salguod
    salguod Member
    234
    37
    Columbus, OH
    Actually, no. The rear has separate shocks and springs. The front uses "MacPherson Struts" (or something like them) which is a unit that includes the damper (shock) and the spring in one unit. The rear has a more conventional spring and separate shock. The strut (with the spring) comes out as one unit and then the spring can be separated, the springs & shocks don't necessarily.
    A broken spring should be easy to see. Have the mechanic point it out to you if you're skeptical.
  8. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    Not so unusual in the rust belt.
    Often there's an uncoated spot where the hanger contacted the spring during coating. It starts there and propagates with repeated stresses.
    I've had broken springs this way in a BMW and a Subaru, around 9 years in.
  9. Mike500
    Mike500 Senior Member
    2,593
    764
    As I recall, from my first Strength of Materials Course, taken as a Freshman, 47 years ago, The failue of a high stressed hardened spring begins with the fracture of the first molecular layer.
  10. emeyer
    emeyer Junior Member
    we have had this issue on our 05 - Perhaps a bad batch of springs?
  11. Oracle617
    Oracle617 Member
    30
    36
    I've replaced broken rear springs twice, both on 2005 Prius. One had 125,000 miles, the other 160,000 miles. In each case, the lower most turn of the spring had broken off about 1.5" from the end. The springs are changed as a pair - you can see in the picture below the lower most half turn broken off of one spring.
    Patrick Wong likes this.
  12. Priusyipee
    Priusyipee Active Member
    350
    269
    Upstate New York
    Ditto. At approx 150,000mi my 2005 had the same problem but the issue was both springs. Replaced the shocks/springs on both sides. An alternative move would be to get the OEM parts online and have them installed either at the dealership or a trusted mechanic if not doing it yourself.
  13. eugsal
    eugsal Junior Member
    Exact same broken spring location on my 2005 Prius. Has 184,00 miles on it. Need a manual to show how to get to top of shocks
    for removal. Any suggestions?
  14. exstudent
    exstudent Senior Member
    2,213
    901
    Torrance, CA
    Its called search. Type "rear shock replacement."
    Consider a temporary subscription to Toyota's TIS (Technical Information System). You will have access to factory manuals and wiring diagrams.
  15. goldfinger
    goldfinger Active Member
    535
    402
    Buffalo
    I had a broken rear coil spring on my 2005 at 110k. It was just the very end of the spring so the car wasn't sagging. Discovered while having tires installed. I replaced both springs and shocks while I was at it.
