Broken rear Strut spring
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mrkihn, Apr 2, 2015.
  1. mrkihn
    mrkihn Junior Member
    Erie, PA
    Hi there
    I have a 2006 Prius with 75k miles on it . I installed a trailer hitch on it last week for doing some light weight hauling of things. I jacked the car up with a heavy duty jack that can lift one whole side of car up and put a jack stand on rear jacking notch I then jacked the other side car up and did same thing . I have done this many times before normally just for rotating tires . After installing hitch I lower the car slowly back down and than I sat down on the bumper to do the inside wiring. As I sat down I heard a big thunk. I got off the bumper and didn't notice to cause that noise so I proceeded to finish wiring and as I shut the hatch I heard another thunk. To make this story shorter , I looked at car and it looked like it was sitting lower in rear . Yesterday I jacked car back up to see what the trouble was and found the strut spring on the rear drivers side broken . Has any body every heard of this . Didn't hit any hard bumps to cause this and like I said earlier the car was lower down slowly and not just dropped down. Was there a recall for the struts or has anybody else heard of these springs breaking . Is there a better replacement for strut and spring assy. Local auto parts store don't even have a spring listed for replacement but they do carry the strut itself .
  2. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    225
    Harrisburg, PA
    It's common in many cars. They break because they get rusty. If you want springs try a set of lowering springs or the dealer or junkyard/eBay
  3. Mike500
    Mike500 Senior Member
    2,593
    764
    The springs are made of a heat treated steel alloy. They are susceptible to "stress corrosion cracking."
    The first thing I learned in material science engineering is that "The failure of anything starts with the destruction of the first molecular layer."
    Heat treated alloys are very susceptible to "stress corrosion cracking, " which easily migrates through the entire crystalline structure of the alloy.
    trentofdestiny likes this.
