Broken Rocker Arm w/ no symptoms?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by daveny, Nov 22, 2013.
  1. daveny
    daveny Junior Member
    Syracuse, NY
    2005 Prius with 100k on it in the snowy, salty winters of upstate new york. Took it in for scheduled maintenance and snow tires today, and wound up getting hit with a diagnosis of a cracked rear spring and a broken rocker arm. Which will cost an arm and a leg to fix.
    Here's the thing though -- I haven't noticed any "symptoms" of either problem. No knocking or noticeable loss of power, and no bottoming out or sliding out driving.
    The dealer has usually been pretty good, but I'm just a little baffled by having two such serious issues going on (and going unnoticed by them just a couple thousand miles ago) without any symptoms. Thoughts?
  2. vskid3
    vskid3 Active Member
    773
    228
    You could try checking the spring yourself. I would get a second opinion and don't tell them what the dealer said was wrong, just that they said there was an issue. If they come back with the same diagnosis, then they were telling the truth.
    I'm not sure how they could tell that a rocker arm is broken without taking the engine apart. Are you sure that's what they said?
  3. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    I had a broken rear coil on my 2005 at about 110k. I also live in NY the state of salt. It was the very end of the coil so it didn't sag or behave noticeably bad. I had both coils replaced and the shocks as well since it was no additional labor. The car drives like new. I can't believe the rear suspension makes that big a difference.
    Concerning your control arm it must not have been broken all the way through or I think you would have known.
  4. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    The ICE would not work if it had a broken rocker arm. I suspect they said "control arm" which is a part of the suspension.
    xliderider likes this.
  5. Mike500
    Mike500 Senior Member
    2,593
    766
    Rocker arm?
    I thought it was the part that controls one of the valves inside the engine. But then, the 1.5L engine has overhead cams.
  6. Priusyipee
    Priusyipee Active Member
    354
    269
    Upstate New York
    Perhaps it was an idler arm in need of replacement? I, too, live in upstate NY and had the springs and shocks replaced on my '05 last November at about 150,000 miles. Car runs flawlessly. What a difference.
  7. bisco
    51,154
    o/p is unclear. no knocking or noticable loss of power = ice? no bottoming out or sliding out driving = suspension?:confused:
  8. Mike500
    2,593
    766
    Does the OP mean that it's the "trailing arm" on the axle beam? That cost over a thousand dollars just for the part.
    The rear suspension doesn't have MacPherson struts.
    If you can get them, used parts from a wrecking yard from a Arizona or Southern California low mileage car might be your best bet. Then, the sipping for a large part might be a killer.
  9. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
    I noticed that too, but as pointed out earlier, how can one diagnose a broken rocker arm without engine disassembly?
    The OP probably misunderstood the rocker arm part of the diagnosis.
    SCH-I535
  10. Priusyipee
    354
    269
    Upstate New York
    I made an appointment to get an alignment last year around mid - October. The dealership had an alignment special too good to pass up. I did not take it to the Toyota dealer. I took it to a Honda dealership. I was told that my right rear coil spring was cracked at the end. Therefore, the car could not be aligned. The crack was obvious at all. The car did not sag nor did it clunk. There was no drop off on mpgs. HOWEVER - the road noise DID increase. I did not realize just how much until the springs and shocks were replaced. I ordered the OEM Toyota parts online through Toyota dealer and had them installed locally. I also asked for the used parts to be returned for my inspection. Car has over 190,000 miles and still going strong!
  11. Mike500
    2,593
    766
    I see you have a 2005. Do you have "coil over" shocks or springs with shocks outside of the springs?
    The later configuration is less expensive to replace, since it is less labor intensive.
    Because both springs and shocks are worn, they should be replaced in pairs.
  12. Patrick Wong
    18,200
    6,493
    The front is Macpherson struts (coil surrounds the strut) while the rear is coil over shocks.
    cwerdna likes this.
  13. Priusyipee
    354
    269
    Upstate New York
    Yup - replaced in pairs and both sides. Just checked the online Toyota catalog which lists both a shock and a strut for the rear of an '05. The strut is more expensive. The coil spring surrounds the shock/strut. No more labor intensive to replace the whole unit. O/P hasn't elaborated since first posting. If Dave was going for new tires, an alignment would make sense. If so, it would make sense if he had a cracked spring and an idler arm that needed replacement. He must have misunderstood the technician.
    REAR SUSPENSION / REAR SUSPENSION / SUSPENSION COMPONENTS / SHOCK ABSORBER
    SHOCK ABSORBER Prius; From 5/03 2004-09 MSRP Core ? Save Online Price
    $42.88 $0.00 $9.86 $33.02
    View Part Diagram -- Item #1
    REAR SUSPENSION / REAR SUSPENSION / SUSPENSION COMPONENTS / Strut
    Strut Left MSRP Core ? Save Online Price
    $68.08 $0.00 $15.66 $52.42
    cwerdna likes this.
  14. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
  15. Patrick Wong
    18,200
    6,493
    The two different listings might be because the Touring model (which was available around 2007) has different shocks/struts on rear/front compared to the Base model.
    The rear part is a shock while the front part is a strut.
  16. Priusyipee
    354
    269
    Upstate New York
    That makes sense - coil spring + shock vs. strut although the 2 parts were listed as a rear component for an '05 when no touring edition existed. Unfortunately, the online catalog does not give specific part numbers... Most likely, their error when constructing the material for the web page.
  17. Mike500
    2,593
    766
    Easy to tell what's there. Just look under the car.
    I believe that the 2005 has spring "coil over" the shocks.
  18. bisco
    51,154
    i still don't understand why it might 'knock or lose power' if it's the suspension?
