Brown Fluid Leak Under Left Rear Door.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by hookbill, May 3, 2014.
  1. hookbill
    hookbill Junior Member
    45
    N.E. Ohio
    I have a leak underneath the rear right passenger door. I see some type of pan underneath there but don't know what it is. Can someone please help identify what this could be? If this question is asked already I apologize, I couldn't find it in search. This is 2011 Hatchback.
    49,445
    just a wag, could it be brake fluid? not sure if any other fluids go to the back.
  3. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    If it is "oily" it is most likely brake fluid. If not, have you removed everything from under the deck and looked for pooled water around the battery or under the spare tire?
